new park light bulbs don't fit old housing
Well, I got a problem a lot of you have probably run into. In converting my 53 f100 to two filiment bulbs for front turn signals I find that the longer bulb keeps the lens from seating. What to do? does somone make a shorter bulb? It will take a bit of cutting and welding to modify the ones in place. Thanks for all the great info I have been getting.
Bob
Bob
I ran into this same issue on my '52, with Dennis Carpenter's "dual filament" replacement assemblies. The problem on mine was that the Chinese shoved the socket too deep into the housing. I had to break the tiny little spot weld and shove it back into the housing about 1/4". After all that, the repro assemblies fit so poorly on the lower valance that I ended up pressing the new sockets into the old OEM baseplates.
If you are working with stock assemblies, I don't think you can do this, because the dual-filament bulbs have staggered pins on their bases. Unless you can cut new ones, it just won't go.
Originally Posted by GreatNorthWoods
Just press the old sockets out in your vice and press in a pair of new ones to the depth you need. That's what I did on my 48. Another option is to use those halogen replacements for 1157 bulbs....they are shorter.
