Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Need help replacing O2 sensors
Old 09-18-2006, 09:45 PM
richert01's Avatar
richert01
richert01 is offline
Question Need help replacing O2 sensors
Hello All,
I am hoping to get your assistance on how to replace the O2 sensors on my 6 cylinder 2001 Ford Escape. It has been hesitating with a check engine light. I was originally advised by a buddy that it was the PCV valve as this needs to be replaced at 100000 miles. Since my truck has 94k I didn't think twice. I changed the PCV valve and the spark plugs as well. The problem seemed to be fixed till I took it on the turnpike and went up to 60mph. The check engine light came back on and it started hesitating along with a rough idle. The check engine light sometimes blinks and sometimes stays steady. Long story short, I took it to Advance Autoparts and had it checked on the computer. It came up as a cylinder 5 misfire and the tech believes it might be the O2 sensor. Hopefully, this is something I can do myself.
Any help is greatly appreciated...
Old 09-19-2006, 06:52 AM
DoctorCAD's Avatar
DoctorCAD
DoctorCAD is offline
Are you sure that its not the cylinder 5 COP?
Old 09-19-2006, 08:38 AM
projectSHO89's Avatar
projectSHO89
projectSHO89 is offline
This is FAR more likely than the O2 sensors....
Advance Auto has "techs"?????? Where did they get them from, AutoZone?
Steve
Old 09-21-2006, 11:40 AM
richert01's Avatar
richert01
Sorry for the delay in getting back to you. I am going to try the boot and spring before I try the O2 sensor as it would be a much cheaper repair attempt. I will let you know how it goes.
Old 09-21-2006, 11:41 AM
richert01's Avatar
richert01
Steve
Meant to say tech, instead. I will let you know how it turns out.
Old 09-21-2006, 04:37 PM
MazdaRangerGuyInSTL's Avatar
MazdaRangerGuyInSTL
MazdaRangerGuyInSTL is offline
The O2 sensor WILL NOT fix a #5 misfire code.
It's possible either somehow the plug is defective (or broke while installing), or the coil itself has some issues. Sometimes they can have a borderline condition and just removing and reinstalling them will cause it to go haywire.
If it were an oxygen sensor, it would affect that entire bank (4,5, AND 6 cylinders). Besides, I believe your vehicle has FOUR of them. Which one do you plan on replacing?
Old 11-10-2006, 09:34 PM
richert01's Avatar
richert01
Hello everyone. Just wanted to say my issue was resolved. It was the COP. Tried cleaning the brass 'insert' to no avail. It did reduce the rough idle, though. In the end I paid $66+ for a new COP. Thanks to all and sorry for the delay in giving a status update.
Old 11-10-2006, 10:14 PM
MazdaRangerGuyInSTL
Hey no problem.. I'm glad to hear that it's fixed.
Congrats!
MartinTravels
05-31-2014 06:52 AM
apcommunicate
1997-2006 Expedition & Navigator
08-30-2013 11:25 AM
90Ford250
04-01-2007 11:42 PM
elsfarm
1978 - 1996 Big Bronco
04-01-2004 08:14 PM
dwayneh
1997 - 2003 F150
09-03-2003 08:45 PM
Quick Reply: Need help replacing O2 sensors
