Need help replacing O2 sensors - Ford Truck Enthusiasts Forums
Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Old 09-18-2006, 10:45 PM
richert01 richert01 is offline
richert01 is starting off with a positive reputation.
Question Need help replacing O2 sensors
Hello All,
I am hoping to get your assistance on how to replace the O2 sensors on my 6 cylinder 2001 Ford Escape. It has been hesitating with a check engine light. I was originally advised by a buddy that it was the PCV valve as this needs to be replaced at 100000 miles. Since my truck has 94k I didn't think twice. I changed the PCV valve and the spark plugs as well. The problem seemed to be fixed till I took it on the turnpike and went up to 60mph. The check engine light came back on and it started hesitating along with a rough idle. The check engine light sometimes blinks and sometimes stays steady. Long story short, I took it to Advance Autoparts and had it checked on the computer. It came up as a cylinder 5 misfire and the tech believes it might be the O2 sensor. Hopefully, this is something I can do myself.
Any help is greatly appreciated...
Old 09-19-2006, 07:52 AM
DoctorCAD DoctorCAD is offline
DoctorCAD is starting off with a positive reputation.
Are you sure that its not the cylinder 5 COP?
Old 09-19-2006, 09:38 AM
projectSHO89 projectSHO89 is online now
projectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant future
Quote:
This is FAR more likely than the O2 sensors....
Advance Auto has "techs"?????? Where did they get them from, AutoZone?
Steve
Old 09-21-2006, 12:40 PM
Sorry for the delay in getting back to you. I am going to try the boot and spring before I try the O2 sensor as it would be a much cheaper repair attempt. I will let you know how it goes.
Old 09-21-2006, 12:41 PM
Steve
Meant to say tech, instead. I will let you know how it turns out.
Old 09-21-2006, 05:37 PM
MazdaRangerGuyInSTL MazdaRangerGuyInSTL is offline
MazdaRangerGuyInSTL is starting off with a positive reputation.
The O2 sensor WILL NOT fix a #5 misfire code.
It's possible either somehow the plug is defective (or broke while installing), or the coil itself has some issues. Sometimes they can have a borderline condition and just removing and reinstalling them will cause it to go haywire.
If it were an oxygen sensor, it would affect that entire bank (4,5, AND 6 cylinders). Besides, I believe your vehicle has FOUR of them. Which one do you plan on replacing?
Old 11-10-2006, 10:34 PM
Hello everyone. Just wanted to say my issue was resolved. It was the COP. Tried cleaning the brass 'insert' to no avail. It did reduce the rough idle, though. In the end I paid $66+ for a new COP. Thanks to all and sorry for the delay in giving a status update.
Old 11-10-2006, 11:14 PM
Hey no problem.. I'm glad to hear that it's fixed.
Congrats!
1999 E250 Rough Idle & Loss of Power MartinTravels 1968-2013 Full Size Vans 3 05-31-2014 07:52 AM
HELP!!! 03 Expedition 4.6L (P2198 & P0306) + Blinking CEL apcommunicate Expedition & Navigator 5 08-30-2013 12:25 PM
Pcv Valve 90Ford250 1987 - 1996 F150 & Larger F-Series Trucks 5 04-02-2007 12:42 AM
94' Bronco Running Rich/ O2 sensor? Help! elsfarm 1978 - 1996 Big Bronco 6 04-01-2004 09:14 PM
Ideas on OBD2 code on 97 F150? dwayneh 1997 - 2003 F150 8 09-03-2003 09:45 PM
Tags
01, 02, 2001, bank, change, cyl, cylynder, escape, fix, ford, o2, oxygen, replace, sensor, sensors, v6oxygensensor
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
