460 C6 passing gear cable - Ford Truck Enthusiasts Forums
Old 09-18-2006, 06:20 PM
ChronGen ChronGen is offline
ChronGen is starting off with a positive reputation.
hi, i did a tranny swap on my 1990 f250 from the auto e4od to the auto c6. the reason i did not use the same trans is because i just simple could not afford to rebuild it let alone purchase another one and i had the c6 lying around that was couple to an '83 carbed 460. what i was told i needed since now my truck only has 1st and 2nd gear is what's called a passing gear cable? i was also told it's called a kick down cable. which is the correct name? are there any other names this part goes by? this is the last thing i need on my truck then she'll be fine after 3 months of just sittin dead. is there anything anyone maybe suggest i do about this? i've already checked allllll the local junk yards, autowreckers, etc... and no one has it. any suggestions would probably hep, thanks in advance!
Old 09-18-2006, 07:08 PM
subford's Avatar
subford subford is offline
subford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud of
The correct name is downshift linkage rod or cable.
Old 09-18-2006, 08:57 PM
2Wise4aGM 2Wise4aGM is offline
2Wise4aGM is starting off with a positive reputation.
I've always heard it called a kick-down cable. Last one that I got for a C-6 I had to get at ford. It was for an 88 F250, and should be the same one you need.
Problems with speedometer cable 91 f-150 I6 m5OD mjricha.isu 1987 - 1996 F150 & Larger F-Series Trucks 5 07-09-2015 07:41 AM
93 F150 Lightning Parking Brake Cable Bracket? luvssunsets2 1987 - 1996 F150 & Larger F-Series Trucks 4 05-30-2015 03:08 PM
92 Ranger shift linkage? callmehero Ranger & B-Series 2 09-25-2014 01:18 PM
Name that part! toothpix 1973 - 1979 F-100 & Larger F-Series Trucks 7 10-30-2013 06:18 PM
68 shortbed 460 hard starting carb backfire corytcline 1967 - 1972 F-100 & Larger F-Series Trucks 25 09-10-2012 09:35 PM
Tags
302, 460, 77, 83, bought, c6, cable, called, e350, f250, ford, gear, linkage, passing, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
