You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
I took my truck in to have an alignment , cause it needed it really bad, The pass front tire was way off and was sticking out still when was supposed to be straight. I pick up my truck 3 hours later and pay my 80.00 and go to drive home. I get out and look at it and they did nothing.. The tire was still way off ballanced and nothing has been moved just like i left it. So i call the manager ( ***) Who then procedes to tell me that there was something wrong with it thats why they couldnt do it and but he didnt know what because the guy has already left, possibly he said because the rust he says and i would have to wait till monday ( this was fri) because the "man" is gone .sunday I did it my self no probs, its not perfect but at least my tire isnt sticking out the wrong direction. MONDAY ....So whats wrong.. so I get the guy who worked on it.. he says , becuase its lifted . (only four inches) and it's because of my gear box leaking like a siv! which it does but thats on the drivers side, then he tells me also because of the drop pitman arm, and because " somebody put u joints in the front end"! WTF! But remember they chargeed me for the job already. so its going back in at there expense on saturday, but they still dont know if they can do it,, it shouldnt be hard now ,, all the tough **** is already done! I just cant believe it! any thoughts on this?
Reason: Removed a name from the rant...
They should still be able to set the alignment correctly. That sounds like a **** and ***** VW stealership response (I know, my daily is a Passat). If they dont fix it im sure you can take it to Leightons garage or Courtney Truck Service on highway 62 in Eden Prarie.
American Goodyear in St. Louis Park is my garage of choice. I have been going there for the last 9 years, and they have always done right by me.
__________________
It is as though I have slain a thousand Philistine’s with the jawbone of an ***, and had my eyes plucked out in vengeful retribution. –JoeCartoon
Aditionaly, a day or two after i got my truck back I started hearing grinding noise comming from the rear. Thought it was a wheel bearing again. So i parked it for a few weeks. (last time the axle came out while driving it). So i decided to check the alxle. Inside the pumpkin was a nice little round rock... Im pretty sure i know where it came from
They can align it with a lift. I did a 08' F-250 last weekend at work with a new lift(done the day before). At least a 6" lift(this thing was a solid front axle with everything from the back of the cab to the front new for the lift). I had to take the 37" tires off because our alignment heads wouldn't fit, and put his stock tires on. It does make it alittle harder to keep the steering wheel straight, it tends to wander. But they can get it into spec at least....
__________________
If it ain't broke.....change stuff till it is!
you SHOULD always be able to align a truck with a lift kit, considering you use all the parts that come with the lift. you need to keep correct geometry of your suspension. As far as i can tell the only way they cant do an alignment is if you have a broken/bad tie rod-end, ball joints shot, and or some other related bushings that can affect an alignment job.
__________________
1990 F-150 XLT LARIAT 4x4
300-6, E4OD
CB Radio
duals
custom rims w/31's
tinted windows
new paint
grille guard
stereo system
3" susp. lift
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
