Wvo - Ford Truck Enthusiasts Forums
Wvo
Old 09-18-2006, 02:34 PM
bassproguy07 bassproguy07 is offline
bassproguy07 is starting off with a positive reputation.
Wvo
Hey Lesk, what would I need to convert my 83 6.9 to WVO? Ive looked on your site and plant drive but only found stuff for newer fords and mercedes. Id just like a list of things Id need to get before running WVO.
Old 09-19-2006, 05:36 AM
leskwvo leskwvo is offline
leskwvo is starting off with a positive reputation.
Looks like your in Tx so not sure you need all the same thing I use up north. But that engine will take one of our standard kits part # TTVTM. $679 + shipping.
You need a second tank, I think your truck comes with two and you need a good source of oil and away to filter it.
Old 09-20-2006, 11:52 AM
Yup Im from TEXAS. I do have two tanks, one in the front holds I think 13 gallons. The one in the back holds 20 I think, not exactly sure. The front would probably be my Pump Diesel tank, seeing how it is smaller and I would only need it to start and stop my engine. If I was to make a home made kit, money is a little tight so saving money is my first priority, which is the reason I want to switch. Do I need a seperate pump? in line filter or is filtering before putting it in the truck good enough? Also, what type of heaters do you recomend?
Old 09-20-2006, 02:46 PM
Quote:
Bassproguy,
Sorry dude. I pay $50 bucks a month to have my little logo up on this forum and be able to hock Plant Drive and my wares. So I'm not in much of a mood to help you design a home made kit. That would be kind of counter productive.
Use Google and you will find all the info you could ever want. Sorry if I'm being a richardhead.
Old 09-20-2006, 04:23 PM
thats fine, i understand
Tags
2005, 83, convert, davidson, diesel, f250, ford, harley, kits, wvo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
