Go Back   Ford Truck Enthusiasts Forums > Diesel > Pre-Power Stroke Diesel (7.3L IDI & 6.9L)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 09-18-2006, 07:46 AM
petepetersen petepetersen is offline
petepetersen is starting off with a positive reputation.
Injector removal and reinstall 7.3 IDI F250 ?
I need to remove the injectors on my 1994 F250 7.3 for testing /replacement. I am not planning to remove the IP nw so what is the best way to get the lines out of the way so I can remove them ? What socket do I use to the injectors them out ? I will buy the o-ring and line kits . Anything else I should look for or do on this injector R&R pocedure ? - Thanks
  #2 (permalink)
Old 09-18-2006, 09:47 AM
PLC7.3 PLC7.3 is offline
PLC7.3 is gaining momentum as a positive member of FTE.
Here is my standard blurb....
Injectors are easy, remove the line cap nuts, gently move the line away sufficient to remove the return lines/caps as a set per side, then using a 1" socket "DO NOT BEND STEEL LINES" unscrew the injector(s). Remove the copper seal if left in the base of the bore.
If major amounts of carbon are found or difficulty in removal of inj or gp place the cylinder at TDC. Clean the inj bore but do not dump carbon into the cylinders, remove the GPs and use a vacuum to clean/suck debris out through either hole.
Send injectors out for pressure testing at a local shop or just buy new ones, also get a return line kit which consists of hose, clamps, orings, copper seals and new injector caps from one of several advertisers here.
Installation is reverse, "DO NOT DAMAGE THE NOZZLE TIPS" you can put the "new kit orings" on the injectors but they come with some on already. To replace useing vaseline or??, roll the first oring into first groove, roll second over it to lower groove trying not to cut them. Put the new copper seal on injector tip, I hold it in place with antisieze, antisieze the body slightly and do the threads, torque to 35lbs, book says twice?. Install the new caps and line "sets" made up "by you" identical to removed sets, use more vaseline inside caps, press down on cap (tops) until they seat into place. Connect the line caps torque is 22 ftlbs.
Now would of course be a good time to replace the IP too as your 75% there.
If you do not replace the IP starting should be no problem as fuel is at the end of the lines already and several cranks will fill injectors.
__________________
93 F250 SC 4x4 E4OD 355LS
  #3 (permalink)
Old 09-18-2006, 10:11 AM
Please excuse my denseness . By the cap nuts do mean unscrew them ony at the injectors and not the IP ? - Thanks
  #4 (permalink)
Old 09-18-2006, 11:25 AM
bilder12 bilder12 is offline
bilder12 is starting off with a positive reputation.
thats right pete, the nut that holds the liine to the top of the injector and VERY CAREFULLY MOVE THE LINE ENOUGH TO REMOVE THE INJECTOR. DONT PUT A KINK IN THE STEEL LINE.
one of the lines has an adapter on it, you will need two wrenches to remove the steel line .. one to hold the adapter and one to loosen the line nut and VERY CAREFULLY MOVE THE LINE TO ONE SIDE ENOUGH TO PUT A SOCKET ON THE INJECTOR TO LOOSEN IT.
once the injector is loosened, use shop air to blow beside the injector body to remove any debris from the port. There is also a copper crush washer that should come out with the injector, if it doesnt come out use a pick to remove it.
to reinstall the copper crush washer, I use some antiseize to hold it in place til installed. Also slight antiseize on injector threads wont hurt.
Be careful installing the new injector into the bore, there is small needle extension on the injector tip that you dont want to break or bend.
Its relatively easy, just pay attention to what you are doing.
__________________
2000 super duty f-350 crew cab with training wheels, ats flip chip controller - hang on to it ! I did the air intake too - best thing since sliced bread.
  #5 (permalink)
Old 09-18-2006, 10:40 PM
KJLYPW's Avatar
KJLYPW KJLYPW is offline
KJLYPW is starting off with a positive reputation.
You may want to remove the two clamps that hold the lines togeather on each set of lines to help with access to the injectors. Gives you a bit more flexability in the lines. DON't forget to put them back on when done. Cheers
__________________
Kevin L.
93 F350 7.3 IDI 4x4, E40D with Multi Disc TC, Ram air, Stans Headers, 3" to Y- 4" exhaust,3.55, B&M shift plus, Pyro, Fuel opened 1-1/2 flats- Happy with power increase!
48 F-68 Stock- in restoration
  #6 (permalink)
Old 11-01-2009, 02:21 PM
f350fan1993 f350fan1993 is offline
f350fan1993 is starting off with a positive reputation.
How about removing a half of an injector that stuck in the head? I'm at a loss with that, because half of one of my injectors did that, i need to change it to get rid of the miss in it.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
