Need info... towing auto carrier
I just need some info from somebody that has any experience in car towing. I'm going to tow a car (66 Chevy Nova) from Tucson to Salt Lake City using a car carrier (no idea on what kind.. yet) and towing it with my 2004 Ford explorer XLS 4x4, that has a class 2 towing package. My question is will I be able to accomplish this safely and are there any problems that I might encounter??
If you have the Class II hitch (1-1/4" receiver) your tow rating is around 3500# (3.55 rear gears and no engine oil cooler for the V6); the trailer and Nova will be WAY over that. CAN it be done........sure. SHOULD you do it.........that's up to you but IMHO you need a more-suitable tow vehicle. Also, if you're thinking of renting a car carrier from U-Haul, they won't do it.
Welcome to FTE!
Steve
Welcome to FTE!
Steve
boo hoo
Thanks for the info...
so if I uprgrade the hitch to a class 3 and get an oil cooler it might work?? I just want to get this done without having to rent a U-Haul truck. Also will the suspension be OK or should I uprgrade the shocks, springs, etc., the truck has about 28K miles on it.
Another possibility or at least something to think about is a tow dolly. It would be less overall weight to pull and less width too. But either way the class 3 hitch is a must along with the trans cooler. And it's true, U-haul won't rent a car trailer or tow dolly for towing with an Explorer. You could buy a good used tow dolly for less than Uhaul wants for a one way rental of their smallest truck and car trailer combination. Check out the Uhaul web site. Penske rentals won't rent a car trailer unless you rent their truck too. More things to think about.
Austrian F100
05-21-2004 01:11 PM
