Heater Hose Disconnect Tool - Ford Truck Enthusiasts Forums
Aerostar Ford Aerostar
Old 09-17-2006, 06:16 PM
Vegas Van Vegas Van is offline
Vegas Van is starting off with a positive reputation.
Question Heater Hose Disconnect Tool
Hi,
I need to change the water valve on my 95 shorty.In order to get the hose clamps off the water valve[on upside down]I need to get the heater hoses off the heater core.My service manual says use Heater Hose Disconnect Tool #T85T-18539-AH.I don't have one.Is there a way to remove these hoses using common hand tools?
Thank you in advance for any advice.
Old 09-17-2006, 07:22 PM
roree roree is offline
roree is starting off with a positive reputation.
The location of these clamps makes it difficult to easily remove them. You need to push the clamp foreward while pulling the collar back. Some guys with small hands have claimed to do this by hand. Once the clamps are removed I have been told that a new o-ring should be used in the old clamp. You can get the tool from local auto stores or from online auto suppliers like Whitney etc.
Old 09-17-2006, 09:57 PM
lv2race's Avatar
lv2race lv2race is offline
lv2race is gaining momentum as a positive member of FTE.lv2race is gaining momentum as a positive member of FTE.
After you remove them, cut the connectors off and use hose clamps.
Old 09-17-2006, 11:25 PM
96_4wdr's Avatar
96_4wdr 96_4wdr is offline
96_4wdr is gaining momentum as a positive member of FTE.
don't expect the Ford special tool to be a miracle tool on these fittings....corrosion, goop, crud binds the fittings....age destroys the plastic....things break
Ford special heater hose connections
Old 09-18-2006, 12:41 AM
lv2race's Avatar
Also, most after market heater core ports are not perfectly round, which makes attaching the hose connector a pain in the behind. Even if you grease inside the fitting, they are very difficult to attach.
Old 09-18-2006, 02:12 AM
xlt4wd90's Avatar
xlt4wd90 xlt4wd90 is offline
xlt4wd90 is gaining momentum as a positive member of FTE.
All the suggestions I've come across regarding this advise to just cut off those silly plastic quick-connect ends and re-connect with regular hose clamps. You can save yourself a lot of grief by choosing this route from the begining. When you do, the easiest way to release those clips is by jamming a flat bladed screwdriver into one of the slots on the side of the coupling, and breaking it apart. This will allow the little white plastic clips to be easily removed, and then you can easily pull the couplers off the core nipples.
You might need to splice in some more hose sections to get the chopped heater hoses to reach the core nipples again. The easiest way to tighten the hose clamps onto the hoses around the core nipples is to use a ratcheting box end wrench. Otherwise, tightening those clamp screws will be frustratingly tedious.
Old 09-18-2006, 11:40 AM
aerocolorado aerocolorado is offline
aerocolorado is gaining momentum as a positive member of FTE.aerocolorado is gaining momentum as a positive member of FTE.
I've used aftermarket quick release tools as well as the genuine McCoy, the Ford tool, and none of them work as well as you would expect. As alluded to above, grime, grit and crude make the couplings difficult to separate. They don't just "pop" apart despite what the manuals lead you to think. They will come apart but it takes some fiddling around to get the hang of doing it with the tool. They do however, snap back together very easily. Ford dealers sell replacement kits (around $6.00) but make sure you know which size tubing connectors you are working with.
Old 09-19-2006, 12:54 PM
Baggins Baggins is offline
Baggins is starting off with a positive reputation.
I could never find the tool and finally gave up, cut them off and used clamps to reinstall, but it did take a stubby screwdriver and some contortion to get the clamps tight again.
Old 09-19-2006, 02:05 PM
96_4wdr's Avatar
3/8" drive sockets, extensions and u joints work well also
Old 02-19-2007, 03:08 PM
AerostarDad's Avatar
AerostarDad AerostarDad is offline
AerostarDad is starting off with a positive reputation.
""but make sure you know which size tubing connectors you are working with""
What are the different sizes? I guess I have to have the old core out to determine the size before I buy the new O ring kit? Sure would be nice to have all the parts bought to get the job done in one step.
Old 02-19-2007, 04:49 PM
ken1mod ken1mod is offline
ken1mod is starting off with a positive reputation.
In order not to damage the heater core in my case, I used a hack saw blade heated red hot by a propane torch to cut the plastic quick connect part. takes about 30 sconds and does not stress the metal tube. hose clamps are now doing the job well.
ken
Old 02-19-2007, 07:27 PM
There are two sizes, a 3/4 inch for both heater core connections and a 5/8 inch on the ends that connect to the engine side. Ford dealers sell a little package with the plastic clip, spacers and o-rings. However, when they do a part look up, the 5/8 inch size comes up first. The first time around, I had to go back to get the correct size I needed. Also, it would be a good idea to purchase a spare connector set (3 sets total) as it is easy to foul up and break one. Last tip: You place everything (o-rings, spacers and plastic bale) inside the connector housing, lubricate it with oil or WD-40, THEN line up the hose with the core fitting and slide it on. (No tools needed) There should be an audible 'click' when it seats. Do the bottom first for obvious reasons.
Lastly, this is your blood sacrifice to join the brotherhood of the Order Of The Aerostar! If this makes no sense now, it will shortly.
Old 02-19-2007, 08:34 PM
duplicate post...sorry
Old 02-19-2007, 08:35 PM
Aerocolorado...thanks for the reply. I was just at the parts store,looking at the replacement core, and I noticed the core has 2 different sizes of tubes. I guess I need one package of each size then.
I may go the "cheapskate route", and just cut off the funky connectors and use hose clamps. I'm not planning on keeping the Aero* long enough to have to do this job again...I hope!
And, AeroColorado, I did check out your very in-depth explanation of how to do this swap-out....very informative. Thanks for taking the time to do it!
Old 02-19-2007, 11:53 PM
96_4wdr's Avatar
replace with hose clamps only
will really appreciate the hose clamps if hose fails 30 miles up logging road or on trip far from home and a stocking Ford parts dealer that has inventory
we love our AeroC, he's our top blood donor...has transfused an EXT all from his knuckles and fingers
Extra Ignition Key sweetoldbill 1999 to 2016 Super Duty 2 04-17-2016 06:55 AM
Ignition Coil starting voltage ss0345 1987 - 1996 F150 & Larger F-Series Trucks 0 08-15-2015 10:34 AM
EGR delete Kit Installation TIPS phantomphixer 6.0L Power Stroke Diesel 16 04-04-2015 02:21 PM
My version of the Exhaust brake mod. Kwikkordead 1999 - 2003 7.3L Power Stroke Diesel 63 06-21-2013 10:06 AM
Spongy Brake pedal phantomphixer 6.0L Power Stroke Diesel 2 03-22-2012 06:43 PM
Tags
aerostar, clamps, clips, connect, core, disconnect, ford, heater, hose, plastic, quick, remove, rings, t85t18539ah, tool
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
