Horn and Horn relay location on 1999 explorer xls? - Ford Truck Enthusiasts Forums
Old 09-17-2006, 09:49 AM
Dirt1dobber Dirt1dobber is offline
Dirt1dobber is starting off with a positive reputation.
Question Horn and Horn relay location on 1999 explorer xls?
Just purchased a 1999 explorer xls and the horn doesn't work,does anyone know where the horn and the horn relay are located on this vehicle?
Old 09-17-2006, 10:30 AM
scucci's Avatar
scucci scucci is offline
scucci is starting off with a positive reputation.
Horn is left front of vehicle below bat- remove wheel well apron or get to it from underneath the chassis. Horn relay is in the fuse box on the wheel well. Horns are a common failure item.
Scucci
Old 09-17-2006, 10:38 AM
Wanted to thank you for the info,i'll check it out,hope it solves my problem!
Old 09-23-2006, 03:12 PM
Thumbs up Thank You
Wanted to thank you for the horn relay info, found out there was no relay in the fusebox,installed a new relay and it worked,saved me the trouble of tearing the truck apart to get to the horn. Thank You!
1999 f250 horn location bobiker 1999 - 2003 7.3L Power Stroke Diesel 5 05-11-2014 07:32 AM
2004 f350 horn relay and horn location rhcdjr 1999 to 2016 Super Duty 0 05-08-2010 01:30 PM
99 Explorer Horn/ No Horn wiznewski Explorer, Sport Trac, Mountaineer & Aviator 0 01-28-2006 06:58 AM
98 Explorer horn oskie Explorer, Sport Trac, Mountaineer & Aviator 4 01-27-2006 12:38 AM
92 f150 with cruise = horn relay country boy 1987 - 1996 F150 & Larger F-Series Trucks 11 11-08-2002 04:30 PM
Tags
1999, 2009, 99, blow, diagram, expedition, exploar, explorer, fi50, ford, fuse, horn, location, relay, v8, xls
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
