Go Back   Ford Truck Enthusiasts Forums > Misc. > Offroad and 4x4
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Offroad and 4x4 SPONSORED BY:
Is F-150 Still King?
  #31 (permalink)
Old 03-29-2008, 08:36 PM
HighProCam's Avatar
HighProCam HighProCam is offline
HighProCam is starting off with a positive reputation.
I admit this wiring diagram is a little redundant…
It offers multiply ways to kill a runaway pump
As well as strong power to the Pressure Switch and York
I found it in my York install folder
Here is a little detail if anyone is interested in making there own dip stick, keep that oil right
__________________
78 F250 - I traded a Jeep for my Truck......
http://i30.tinypic.com/2ytuqg1.jpg http://i30.tinypic.com/iv8ks5.jpg http://i26.tinypic.com/20iwhsp.jpg
  #32 (permalink)
Old 03-29-2008, 09:25 PM
captain p4's Avatar
captain p4 captain p4 is online now
I'll sleep when I'm dead
captain p4 is a splendid one to behold captain p4 is a splendid one to behold captain p4 is a splendid one to behold captain p4 is a splendid one to behold captain p4 is a splendid one to behold captain p4 is a splendid one to behold captain p4 is a splendid one to behold
Mine is wired directly, only way to kill it is the pressure switch. I want to clean up my wiring eventually though and the diagram should help.
__________________
-Paul
-88 Mustang 5.0/5spd mild restoration in progress
-78 Bronco 460 and things
-2003 F350 Supercab shortbed FX4 6.0 PSD
Quote:
Originally Posted by STGFordCrazy04 View Post
  #33 (permalink)
Old 05-16-2009, 12:43 PM
BradyCouchman's Avatar
BradyCouchman BradyCouchman is offline
BradyCouchman has a great reputation on FTE. BradyCouchman has a great reputation on FTE. BradyCouchman has a great reputation on FTE. BradyCouchman has a great reputation on FTE. BradyCouchman has a great reputation on FTE. BradyCouchman has a great reputation on FTE.
so i have read this thread about converting a York AC system into an on board air system. so i have an York out of a DeTomatso Pantera (it was free) and i have some questions.
1. what is the best way to find out what port is in and what is out? or are they all the same, if turning the same direction?
2. i have read that these can get hot and you need high temp lines for about 18 inches, but just how hot does it get?
3.i have some pressur washer hose that says it is good for 140*F and about 2600 PSI (yes two thousand six hundred) would that work?
4. what would be a good max psi to stop the compressor at? or is the compressor not the limeting factor typicly? and it is what ever my tank and lines are good for?
sorry to bring up an old thread just thought it would get more attention
__________________
1970 F-350 Crew Cab long bed
06 Focus ZX3 5 Speed (DD)
Thinking the Government stimulus plan is working is like thinking that taking water form the deep end of a pool and dumping it in the shallow end will raise the water level of the pool.
SoCal FTE Member
  #34 (permalink)
Old 05-17-2009, 08:04 AM
1966Tbird's Avatar
1966Tbird 1966Tbird is online now
1966Tbird is starting off with a positive reputation.
would this work with my stock a/c unit? 89 f-150 302 aod not sure who makes the ac compressor though here is a pic i broke the condensor but have a new one waiting to be put on and it's been waiting for 2 years because i don't need a/c in this truck since i have 5 windows that open and it's a reg. cab the compressor still works great to my knowledge
__________________
89 F-150 leveling kit 33x12.5 BFG All-Terrains, Trick Flow Fast as Cast Heads, Comp Cams Gold Roller Rockers, Edelbrock RPM Air Gap Intake, Trick Fuel 750 Mechanical Secondary Carb, MSD E-Curve Distributor, Comp Cams 280hr Roller Cam, Comp Cams Roller Lifters, Comp Cams Valve Springs, Trick Flow Pushrods, DSS Main Girdle, ARP Bolts, Cometic Gaskets, Forged Pistons, 125 Shot of Nitrous, AOD, 3500 TCI Stall Converter, Lentech Street Terminator Valvebody, 4.56 Gears, Flowtech Headers, 2.5in Exhaust
  #35 (permalink)
Old 05-17-2009, 01:45 PM
the reason people use the York style is because they have their own oil for lub. many other styles use the Freon to lub the compressor, and that at lest to me does not look like a york compessor, so i would say dont bet on it.
__________________
SoCal FTE Member
  #36 (permalink)
Old 05-17-2009, 01:49 PM
big bad 79 bronco big bad 79 bronco is offline
big bad 79 bronco is starting off with a positive reputation.
now with a a/c compressor it has to have oil in it all the time do u put oil in it manually and how often i dont c this working for long if it is not oiled very often
  #37 (permalink)
Old 05-17-2009, 10:37 PM
1966Tbird's Avatar
i've never used it other than one time and i havn't ever oiled it
__________________
  #38 (permalink)
Old 05-19-2009, 01:42 AM
HighProCam's Avatar
Quote:
On the top of the York it will say 'Disch' discharge on the left if the pulley is facing you, and 'Suction' on the right if it turns clockwise. There is also a big 'S' cast into the suction side.
What kind of test would you guys like to see?..... I run mine max 225 psi to a 12 gallon tank. So I could do 100 to 150 psi at idle speed to my 12 gallons.
From my experience, the york will get to hot and blow it. But my extreme duty has a lot to do with that.
I would stop it at 150 psi and at least a 5 gallon tank. You could run anything air powered on a 145 pressure switch.
Some more info for the Air Thread
__________________
  #39 (permalink)
Old 05-19-2009, 10:56 PM
fishmanndotcom's Avatar
fishmanndotcom fishmanndotcom is offline
fishmanndotcom has a great reputation on FTE. fishmanndotcom has a great reputation on FTE. fishmanndotcom has a great reputation on FTE. fishmanndotcom has a great reputation on FTE. fishmanndotcom has a great reputation on FTE. fishmanndotcom has a great reputation on FTE.
oba on my powerstroke with IC!
http://picasaweb.google.com/WunTunEa...eat=directlink
-cutts-
__________________
My Google Photo Gallery
-96 F350 4x4 ZF5 CC/LB, 37" SSR's, D66 turbo, Stage-1's, Banks IC, 5" stacks, York OBA
-72 Bronco 302/NP435/D20/D60/10.25 welded F/R, full hydro, hydroboost, 39"iroks
  #40 (permalink)
Old 05-23-2009, 10:37 AM
KubotaOrange76's Avatar
KubotaOrange76 KubotaOrange76 is offline
KubotaOrange76 has a very good reputation on FTE. KubotaOrange76 has a very good reputation on FTE. KubotaOrange76 has a very good reputation on FTE.
mmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmm
__________________
-2007 3500 4x4 DRW G-56 5.9 58,500k-
-1989 f-150 2wd xl lwb reg cab 300-6 2.73 198k..EGR & kitty deleted-
-79 f-150 4x4 400/c6/205 $500 beater in progress-
-See my gallery for pics of my old truggy on 44's-
Tags
ac , compressor , suction
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
