Go Back   Ford Truck Enthusiasts Forums > Misc. > Offroad and 4x4
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Offroad and 4x4 SPONSORED BY:
Is F-150 Still King?
  #16 (permalink)
Old 09-18-2006, 11:41 PM
chrono4's Avatar
chrono4 chrono4 is offline
chrono4 is a name known to all chrono4 is a name known to all chrono4 is a name known to all chrono4 is a name known to all chrono4 is a name known to all chrono4 is a name known to all
Awsome Pro, it'll just make a more in detail tech article on how to do it the "right" way
__________________
--Andrew--
Rocking a 79' f150 with a 300 and a 4 speed........
Full York OBA Install
Welding a 9"
Very simple front bumper
Lowering Spring Towers
Hi, I'm Andrew and I have a wheelin problem that is often disrupted by fabbin and drinkin, glad to meet yall.
STGs MinionsTechnical Advisor
  #17 (permalink)
Old 03-25-2008, 11:52 AM
HighProCam's Avatar
HighProCam HighProCam is offline
HighProCam is starting off with a positive reputation.
Bump. Just some tech to add to the OBA install
The York 210 is the best york as it moves the most air (10 cu in per revolution) the York 209 is next best and so on.
Ideally you should mount the York Vertical as it has its own crank case with oil in it. It will reduce oil blow by.
I believe its suppose to have about 12 to 14 oz, I use straight 30 weight oil.
You can add oil through the bolt in the center on either side of the York. I recommend taking some stiff wire and fashioning a dip stick to check it from time to time.
It is recommended that you run at least 18" of steel braded hose after the York as it can get pretty warm under load. After that a check valve to keep the air from backing out and a coalescent filter would be good as it will keep the water and oil from accumulating in the bottom of your air tank.
I've ran my York at 225psi for at least 3 years now 12 gallon tank, no problemo. I also wired up an indicator light that comes on when the belt clutch engages
__________________
78 F250 - I traded a Jeep for my Truck......
http://i30.tinypic.com/2ytuqg1.jpg http://i30.tinypic.com/iv8ks5.jpg http://i26.tinypic.com/20iwhsp.jpg
  #18 (permalink)
Old 03-25-2008, 01:27 PM
chrono4's Avatar
I kept mine full, and also put some air tool oil down the intake regularly.
Thats what leaving as much a possible of the high pressure side takes place of. It's very heavy high temp line.
I didn't have a check valve, but never had a problem with it bleeding off. I put a petcock in the bottom of my tank so I could drain it.
gdg10cl.....
__________________
--Andrew--
Welding a 9"
  #19 (permalink)
Old 03-25-2008, 02:01 PM
captain p4's Avatar
captain p4 captain p4 is offline
I'll sleep when I'm dead
captain p4 is a splendid one to behold captain p4 is a splendid one to behold captain p4 is a splendid one to behold captain p4 is a splendid one to behold captain p4 is a splendid one to behold captain p4 is a splendid one to behold captain p4 is a splendid one to behold
I've been using the stock line as well with no problems
__________________
-Paul
-88 Mustang 5.0/5spd mild restoration in progress
-78 Bronco 460 and things
-2003 F350 Supercab shortbed FX4 6.0 PSD
Quote:
Originally Posted by STGFordCrazy04 View Post
  #20 (permalink)
Old 03-25-2008, 02:28 PM
HighProCam's Avatar
I was running some weaker hydraulic line (rated 1000psi) and it burst at the crimp one time on me. Where the metal fitting ended, I think the heat transferred down the fitting to the hose. No big deal, just an added upgrade to go to a short piece of steel braided line to help dissipate heat. I also might be generating more heat because of the higher pressures.
Also 14oz is plenty of oil for the York.
A check valve is a good thing and as another upgrade to use the "DOT push-on" fittings. I prefer the Parker brand, there the best hands down.
A coalescent filter is also a real good idea, it will keep stuff out of your tank and most importantly your tools
I mention the pressure and volume just to show people who are thinking about this mod, that the York is a really tough air pump and will take some abuse.
One day I hope to 4 link my truck and bag it on all corners, maybe...
__________________
  #21 (permalink)
Old 03-25-2008, 02:34 PM
captain p4's Avatar
Oh yeah, I'm only running somewhere between 110-125 psi, didn't have the $$ to use fittings/lines/tanks for higher pressures at the time. I want to bag my bronco some day too, but that's going to have to wait. A long time.
__________________
-Paul
  #22 (permalink)
Old 03-25-2008, 02:41 PM
STGFordCrazy04's Avatar
STGFordCrazy04 STGFordCrazy04 is offline
STGFordCrazy04 is a splendid one to behold STGFordCrazy04 is a splendid one to behold STGFordCrazy04 is a splendid one to behold STGFordCrazy04 is a splendid one to behold STGFordCrazy04 is a splendid one to behold STGFordCrazy04 is a splendid one to behold
is that a K&N? How much extra horsepower do you think it gives your compressor?
__________________
Kris
Please do not PM me. My email is STGCountryboy312 at AOL dot COM
Quote:
Originally Posted by thorseshoeing
Yes you are the anti christ...
  #23 (permalink)
Old 03-25-2008, 02:43 PM
captain p4's Avatar
hahaha, I have the same one on mine
__________________
-Paul
  #24 (permalink)
Old 03-25-2008, 04:06 PM
chrono4's Avatar
I'm thinking it's at least good for 15 hp at the wheel But really, it was just the cheapest filter I could find that actually had some decent surface area. I looked at pcv breather filters, but they're just so small.
__________________
--Andrew--
Welding a 9"
  #25 (permalink)
Old 03-25-2008, 04:10 PM
chrono4's Avatar
And on the mounting it vertically........ Ford put mine horizontally so thats how it stayed. Worked for them for 30 years, so I'm gonna roll with it.
__________________
--Andrew--
Welding a 9"
  #26 (permalink)
Old 03-25-2008, 04:49 PM
HighProCam's Avatar
Quote:
Mounting it Horizontally is acceptable, but vertical is "Ideal". Either way works.
Ford put an Air Conditioner in your truck, which pumped AC stuff, not Air.
Mounting it vertical will keep the oil in the crank case "better", keeping the oil from following the air out of the York.
__________________
  #27 (permalink)
Old 03-25-2008, 07:43 PM
Easy! Dyno that Motha'!
__________________
Kris
  #28 (permalink)
Old 03-25-2008, 07:51 PM
MBBFord's Avatar
MBBFord MBBFord is offline
MBBFord is a splendid one to behold MBBFord is a splendid one to behold MBBFord is a splendid one to behold MBBFord is a splendid one to behold MBBFord is a splendid one to behold MBBFord is a splendid one to behold MBBFord is a splendid one to behold
Don't forget to put some go fast stickers(K&N Flowmaster) on the tank and compressor.... at least a extra 25 horses!
__________________
79 Bronco 400 C6 NP205 D44 9" 4.56 gears Lockers 6" lift and 37" SS Iroks
77 F-100 302 C4 D44 31" M/Ts
04 F150 Lariat Screw 4x4 2"AS 32x11R17 Hankook M/Ts or 34x10.50-17 SS LTBs
  #29 (permalink)
Old 03-29-2008, 12:14 PM
HighProCam's Avatar
Here's a little wiring diagram for the York in setting up your OBA
__________________
  #30 (permalink)
Old 03-29-2008, 12:57 PM
chrono4's Avatar
You don't need all of that. One toggle switch and one pressure switch will work just fine. Put the power to the toggle from the ignition, to the the pressure switch, to the a/c clutch.
__________________
--Andrew--
Welding a 9"
Tags
ac , compressor , suction
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
