84 f150 wiring diagram - Ford Truck Enthusiasts Forums
Old 09-16-2006, 06:05 PM
jano jano is offline
jano is starting off with a positive reputation.
I bought this very used 1984 f150 about 5 years ago. Someone had put it a 350 in it and rewired it. Lots of wires that don't go anywhere, just taped off. Last week I drove it home, next day it wouldn't start, no lights, nothing. Battery and cables are good. Appears a wire from the harness to the solinoid was fried. In the process of trying to track down a possible open wire/short the entire harness started to disintegrate on me. I probably need to get another one, but need a diagram to know what wires go where. Any ideas on what wire this was and/or where I could get a diagram and a different harness?
Old 09-16-2006, 06:18 PM
Franklin2's Avatar
Franklin2 Franklin2 is offline
Franklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant future
A smaller wire hooked to the solenoid underneath the large wire going to the battery +? If so, this is the main electrical feed for the whole truck.
The factory wiring diagrams are made by www.helminc.com. See if they have any in stock. The cheapo haynes manual has a pretty good set in it for 84-86 trucks.
If you want to start experimenting and troubleshooting the wiring, hook a small battery charger up to the battery cables and disconnect the battery. The battery charger has a circuit breaker in it, so if there is a problem, the wiring will not melt till you get it sorted out.
03 F-150 Stereo Wiring Diagram zekelander 1997 - 2003 F150 5 12-04-2013 07:26 PM
2002 F-450 Wiring Diagram sfields 1999 to 2016 Super Duty 0 09-25-2013 04:33 PM
Engine wiring diagram? marky55 Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 7 04-07-2009 02:21 PM
crown vic wiring diagram thepitshop 1948 - 1956 F1, F100 & Larger F-Series Trucks 4 11-15-2008 05:57 AM
6 Disc Audiophile wiring Diagram/info? noahr 2004 - 2008 F150 3 01-11-2005 10:11 PM
Tags
150, 1984, 84, charging, diagram, electrical, f150, ford, free, lights, problems, truck, vacum, wireing, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
