Flathead Engine Color
Old 09-15-2006, 09:01 PM
jreilly57's Avatar
jreilly57
jreilly57 is offline
I brought 'Ol Henry to the shop today to begin the process of getting his 1952 flatty re-built. The mechanic asked me what color engine I wanted (it's red now). On the following web link, it says (on the bottom of the page) that '48 flathead engines were red but then the color changed to green in '52. http://www.vanpeltsales.com/FH_web/flathead_specs-90to125late.htm I have heard other people say the engine should be blue. To be authentic, what should the proper color be? The engine is a '52, but the truck is a '48; To be technically correct should I stick with the '48 color (red) or the '52 color (green?). But then there's that blue color...........
Help!!!!!!
Old 09-15-2006, 10:47 PM
TheSovereign53's Avatar
TheSovereign53
TheSovereign53 is offline
I would go with engine correct color. Old Ford Green. I went with Blue Oval Blue on my Engine, which is period correct paint.
Old 09-16-2006, 12:11 AM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is online now
A more available color/paint that is very near correct is available at tractor stores and auto paint stores: Detroit Diesel Alpine Green, Dupli-Color part number DE1618.
Haven't used it myself. Old Ford Blue matched my body paint, so I went with that.
Old 09-16-2006, 09:49 AM
1952henry's Avatar
1952henry
1952henry is offline
Bill Hirsh 52-53 Lincoln Green for 52 truck engines, I've been told.
Old 09-16-2006, 11:46 AM
TheSovereign53
So I take it you guys agree with engine correct color, not truck correct?
Old 09-16-2006, 02:00 PM
mtflat's Avatar
mtflat
mtflat is online now
Odd question actually, as the 48's and 52's used the same engine. So... both colors are "engine correct". As I see it the only question is: yom correct or paint it like you want to?
Sounds like Joe likes the Ford blue which would contrast nicely with all that red paint on the rest of the truck. Green could also be a good color. Paint it red and it practically disappears when the hood is popped. I like my flatty to stand out a bit. Mine's red in a blue truck.
Old 09-16-2006, 05:37 PM
F6Guy's Avatar
F6Guy
F6Guy is offline
There are pictures of my engine in my gallery and I painted my engine detroit alpine green. It matched pretty damn close to the color that ws on the engine when I got the truck which I also have pictures of. Now keep in mind it probly faded some by hte time I got the truck, but it still matched close. According to a book I bought at books-a-million "Classic Ford F-Series Pickup Trucks 1948-1956" by Don Bunn '48-'51 engines were painted dark red and '52-'53 engines were painted medium green with the exception being some late '51 models being painted green. for those wondering the book states that '54 engines were painted Red while '55-'56 engines were painted yellow. I hope this helps, but I agree with what was stated earlier, paint it whatever color you like.
Old 09-16-2006, 09:48 PM
jreilly57's Avatar
jreilly57
Thanks to everybody for the info. I think I decided to go with the green, as that seems to be the color of the year in 1952. Besides as Mtflat mentioned, with a red truck, a engine color other than red would just stand out a little more. Thanks again.
Old 09-18-2006, 02:41 PM
Fat Fendered Ford's Avatar
Fat Fendered Ford
Fat Fendered Ford is offline
I went to great lengths to figure out the correct color for '52-'53 F-100 engines. They were indeed green. The Krylon Ford Green is incorrect. I'll have to doublecheck the Hirsch paint. I have a can of it but haven't opened it for a while. I seem to recall it isn't quite right either. I got a paint chip from a fellow board member who had scanned an inspection cover with original paint at his local paint shop. It was nearly a perfect match to a bellhousing I had off a '53. I took the paint chip to my local Lowes and had them mix up some Valspar oil based industrial enamel. Check out my paint saga page. Send me your address and I'll mail you a paint chip if you want to have some mixed up.
Good luck!
Ersatzjack
1947 and Older Ford Trucks
01-11-2013 02:00 PM
brit_wheels_fan
04-12-2010 09:05 AM
abe
04-09-2009 04:13 AM
pottman
1997 - 2003 F150
03-11-2007 04:39 AM
fordboy_52
03-27-2006 10:10 AM
Quick Reply: Flathead Engine Color
