Flathead Engine Color
I brought 'Ol Henry to the shop today to begin the process of getting his 1952 flatty re-built. The mechanic asked me what color engine I wanted (it's red now). On the following web link, it says (on the bottom of the page) that '48 flathead engines were red but then the color changed to green in '52. http://www.vanpeltsales.com/FH_web/flathead_specs-90to125late.htm I have heard other people say the engine should be blue. To be authentic, what should the proper color be? The engine is a '52, but the truck is a '48; To be technically correct should I stick with the '48 color (red) or the '52 color (green?). But then there's that blue color...........
Help!!!!!!
Help!!!!!!
Odd question actually, as the 48's and 52's used the same engine. So... both colors are "engine correct". As I see it the only question is: yom correct or paint it like you want to?
Sounds like Joe likes the Ford blue which would contrast nicely with all that red paint on the rest of the truck. Green could also be a good color. Paint it red and it practically disappears when the hood is popped. I like my flatty to stand out a bit. Mine's red in a blue truck.
There are pictures of my engine in my gallery and I painted my engine detroit alpine green. It matched pretty damn close to the color that ws on the engine when I got the truck which I also have pictures of. Now keep in mind it probly faded some by hte time I got the truck, but it still matched close. According to a book I bought at books-a-million "Classic Ford F-Series Pickup Trucks 1948-1956" by Don Bunn '48-'51 engines were painted dark red and '52-'53 engines were painted medium green with the exception being some late '51 models being painted green. for those wondering the book states that '54 engines were painted Red while '55-'56 engines were painted yellow. I hope this helps, but I agree with what was stated earlier, paint it whatever color you like.
I went to great lengths to figure out the correct color for '52-'53 F-100 engines. They were indeed green. The Krylon Ford Green is incorrect. I'll have to doublecheck the Hirsch paint. I have a can of it but haven't opened it for a while. I seem to recall it isn't quite right either. I got a paint chip from a fellow board member who had scanned an inspection cover with original paint at his local paint shop. It was nearly a perfect match to a bellhousing I had off a '53. I took the paint chip to my local Lowes and had them mix up some Valspar oil based industrial enamel. Check out my paint saga page. Send me your address and I'll mail you a paint chip if you want to have some mixed up.
Good luck!
Good luck!
brit_wheels_fan
04-12-2010 09:05 AM
fordboy_52
03-27-2006 10:10 AM
