Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Interior Guides
- How to Reprogram Door Keypad Code
Step by step instructions for do-it-yourself repairs
Door Keypad Code Locations
Found the code on my 2006 F250 PSD
Just bought an 06 Lariat 4x4 FX4 CC Short Box. In the 5700 miles the previous owner ran up he lost the card. Probably while taking that financial bath while trading for a Range Rover! OK. I read alot of posts and here is what I did. Put the drivers seat all the way back. Got upside down in the seat so I could look under the dash with some stability. Hanging out the door didn't work for me. I found the module dead center on the dash about the height of the climate control and forward most (towards the firewall) of all the devices mounted in there. It is black with three connectors that are visible and entering the unit from the bottom. They are grey, green and blue in color. There is a piece of white foam insulation running across it side to side in the space between it and the climate module. The code is printed clearly on a white sticker on the face of the module that the insulation is laying up against. I slid a small mirror (wifes compact) between it and the insulation, with a flashlight on the mirror, I read the code that appeared inverted and backwards. I worked my way out of the cab entered the code and the locks activated as described in the manual. Hope this helps. I can be reached at jploussard@comcast.net is anyone has any questions. The whole dealership $75 thing to get a code just isnt my style. I dont mind paying for what I need to but I didn't need to pay for that. Neither does anyone else. Good luck.
Two weeks ago I traveled 300 miles to get my 2004 F250. The salesman had the truck ready and waiting for me. I didn't think to ask for the code until I was ready to drive away. He left for a few minutes and came back w/o the code, but told me that any Ford dealer will hook-up to the diagnostics port and retrieve the code for free. A few days later I called my local dealer and was told there would be a $25 fee to get the code. Another dealer charges $37.50. So I called the dealership where I bought my truck and told them about their salesman's comment vs the truth and was sent a check to cover the cost. Even at $25, if I had to pay out of my pocket, I probably would have been crawling up behind the dash as well.
Keypad code
xtraveler is correct. If you take the stereo out it is easier to see the code on the sticker. Unfortunately I couldn't see mine at any angle. If you push the insulation up and away from the computer, then take a picture with a digital camera it is much easier. Your camera needs to be about the size of a credit card though.
Found the code on my 2005 F250
Originally Posted by dodgedtheford2long
Thanks guys, I just found my code. I bought a used 2006 F250, and no one knew the code.
I pulled the storage tray/giant ashtray open, and looked up behind the radio. It was a code on a white box.
After trying several times, I followed the above quoted approach (aslo recommended by Fidobob) and found the box/lable/code. For me the keys were 1) using the storage bin area for access, and 2) the comment that the box is mounted on the firewall.
The way I finally found it was by feel - I stuck my arm through the access created by removing the storage cubby, and blindly reached up through the wires and foam, all the way to the fire wall, aiming for the general area of "behind the stereo", and just started blindly gropping. When my hand felt a smallish rectangular box, I thought "That's it!" Follow up visual inspection (which was still not easy - but at least I knew there was something there!) using a flashilight showed the sticker w/ the code.
Dealer would have read the code for free - but this saved me two to three hours driving there and back - thanks to everyone for their input/advice. Hope my description will help some who had difficulty.
Jim
Finding F250 keypad code: Pictoral "how to"
I've gained so much from FTE forums - I decided it was time to try and give something back. So I went back and took some pictures showing how I found the sticker with the keypad code. For reference - this is a 2005 F250 Fx4 CC, SB, Lariat - for what it matters. I hope this will help someone else find their code and minimize the time spent upside down under the dash!
Good luck fiinding your code!
Jim
Jim
Originally Posted by NorCalBusa
With the ignition key, you can also just add a new code. The original one will still be in there, but you can add several additional codes. The steps are in the Owners Manual.
Cut from the 2005 Owner Manual at http://www.analogstereo.com/pdf/om/f...anual_2005.pdf
Programming a personal entry code
To create your own personal entry code:
1. Enter the factory set code.
2. Within five seconds press the 1 • 2 on the keypad.
3. Enter your personal 5-digit code. Each number must be entered within five seconds of each other.
4. The doors will again lock then unlock to confirm that your personal keycode has been programmed to the module.
