1965 Econoline PU Wiring
Hello again, Anybody got a good lead on finding a wiring diagram for a 1965 Econoline Pickup. I have been slowly replacing parts, fuses and fixing wiring but still chasing the same problems. I think the work done before me was not right and I am simply following the same path, I need a diagram to check to see if it is wired right. Thanks in advance, Craig
I have a 65 Manuel and it has no skematic for wire diagrams. The only thing I found was a picture of the fuse box with color codes of wires to the fuses. Maybe Jimbare has a manaul that has a skematic of the wires and colors.
My 64 was a mess when I got it. Someone had put in a pile of red wires and with the harness removed it was a nightmare. I ended up getting 2 more harnesses from some vans and opended the harnesses up and made one good harness out of the 3 harnesses. You may have to do the same.
pcartwright
09-29-2016 07:44 PM
rwriccitelli
11-19-2015 12:22 PM
71 LONG BED
11-26-2006 09:20 AM
