Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Other Ford Engines > 4 Cylinder Engines
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
View Poll Results: can you help w/ my 2.3
can it be adjusted 0 0%
what could it be 0 0%
Voters: 0. You may not vote on this poll
LinkBack Thread Tools
  #1 (permalink)
Old 09-15-2006, 12:19 AM
jayjayb75 is starting off with a positive reputation.
2.3 turbo w/ fuel injection
I took a '87 thunderbird engine out of a t-boned car and put it in a '79 ford courier. I got it all in and now it runs, but extremely rich. So rich it shoots fire out the tail pipe. Is there anyway of adjustment or what could it be?
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 09-15-2006, 08:23 AM
TigerDan's Avatar
TigerDan has much to be proud ofTigerDan has much to be proud ofTigerDan has much to be proud ofTigerDan has much to be proud ofTigerDan has much to be proud ofTigerDan has much to be proud ofTigerDan has much to be proud ofTigerDan has much to be proud of
Hi Jay and Welcome to FTE! Please take a moment to check out the Guidelines as they contain important info you'll need when posting on the site:
http://www.ford-trucks.com/guidelines.html
I'm not sure starting a poll for your first post is the best way to get an answer, but what the heck...
What did you use for wiring, the original T-bird harness or an aftermarket harness? Is it set up so that you can use a diagnostic scanner on it to pull the codes?
My first thought is the fuel pressure regulator. You should check the fuel pressure at the Schraeder valve on the fuel rail, you want to see it in the 35-40 PSI range. If the regulator is bad and it's letting too much fuel through, then that could be the source of your problem. For that matter, make sure you have the vacuum hose to the regulator connected to a vacuum source on the manifold, and if so, pull that hose off and check to see if there's any fuel present in the hose. If there is, then that's a sign of a bad diaghragm in the regulator and it's drawing raw fuel dorectly into the manifold.
Sounds a cool project once the bugs are worked out. Post some pics in your gallery along with that unusual F100 you have in there...
__________________
FTE Moderator
Stop by and see us in the
Northern California Chapter!
Political Correctness is a doctrine, fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end.
  #3 (permalink)
Old 09-25-2006, 12:02 AM
well when I dropped it in I got on-line and found a simplified wiring diagram for the 2.3. http://www.blindchickenracing.com/Ho...birdwiring.jpg (so I stripped off everthing I didn't need) Well, the fuel pressure was the first thing I checked and it's good @ 40PSI.
Does anyone know what my timing should be set at?
I'm know nothing when it comes to these little 4 bangers. Normally if it doesn't have 8 plugs I don't touch it, but this one sounded fun.
  #4 (permalink)
Old 09-25-2006, 01:09 PM
99F150 is starting off with a positive reputation.
I think stock timing is 10 degrees before.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
