f-150 fireing order?
ok heres the problem im haveing, i had to replace the plug wires on my 94 f-150 5.0L and i obviously messed something up. So if anyone could help me out right now that would be great. i was looking for the fireing order on the motor, and the cylander placement order, and the #1 cylander on the distributer cap, pretty much anything i need to re run the wires. any help would be appreciated, and thanks in advance to any help.
Depending on which 5.0 you have, the firing order is either 1-5-4-2-6-3-7-8 (regular 5.0) or 1-3-7-2-6-5-4-8 (5.0HO and 351W). It's normally on a little sticker somewhere near the radiator or on the underside of the hood itself (can't remember which). The cylinders are numbered 1-4 front to back on the passenger side, then 5-8 front to back on the driver's side. There's should be a raised '1' by the terminal for the #1 cylinder on the dizzy cap, and rotation is...dang, I can't remember...it's in my Haynes manual, though. It's either clockwise or counterclockwise! You could have someone crank the engine over while you watch the dizzy with the cap off.
Jason
Jason
If the Haynes manual can be trusted, 1994 and later 5.0L engines have a firing order of 1-3-7-2-6-5-4-8.
Here is a graphic depiction of the cylinders:
FIREWALL
4 8
3 7
2 6
1 5
GRILL
O7DGM mentioned that the Number 1 cylinder is at the 1 o'clock position on the distribution cap, please note that the rotor runs counter-clockwise.
Gig
FIREWALL
4 8
3 7
2 6
1 5
GRILL
Gig
just haveing a little trouble finding out where it goes on the distributor cap, if im standing in the front of my truck looking at the engine, number one is at one o clock? thanks for eveyones patients and help, im really not to good with trucks, im just stealing my brothers user name on here.
