installed autospring, now have ?
#32
Hey guys i just put the Bilstein 5100 shocks on my truck wow!!!!!!! They ride so sweet and the front is 1 inch lower than the rear. I could clear just about up to 35"s, I measured the front and rear, got 38" in the front and 39" in the rear. Now this measurement came from the ground to the top of the wheel well. I put them on myself an it took about 4 hrs total time. The first one took alot of time as doing things for the first time aren't fun. The second went alot faster and the alinment isn't that far off but im going to try an get one done tomorrow. Saved about $125 labor doing it myself. Think about the Bilstein's guys their worth it.
#33
Originally Posted by NASSTY
If you get real anxious to install it you can drive 3 hours to ME and use my garage and lift.
http://img.photobucket.com/albums/v295/mrbuick/Picture027.jpg
#37
Autospring install...
I have photos (before-after) in my gallery of the 2" autospring install. I completed the install start to finish in 1 hour 20 minutes and the most accurate measurements I could make were from the ground to the fender lip. The front went up 2" at the fender and what really surprised me was the amount the front bumper went up from 30-1/4" to 33-1/4".
Prior to ordering the kit I parked my truck on level ground and measured everything as close to wheel centerline as possible with the 2" difference between the front and rear I knew the 2.5" kit would have been to high...it all worked out well
Now...I really enjoy the look and feel while driving... I was never crazy about the high rearend.
#38
After putting on the autospring kit over a year ago I immediatly started feeling some vibrations when stepping on the brake. I ended up having some major brake problems. The guy at my local shop did not see any reason why the autospring kit would cause this but I swear that the second I installed it I started feeling the vibrations. Anybody else have the same problem? Maybe I seriously screwed something up while installing myself.... just curious if anybody else had the same problem.
Sjconnor1
38
03-02-2015 01:41 PM
