Injector questions.....
Old 05-19-2013, 12:51 PM
fullsize4wd's Avatar
fullsize4wd
fullsize4wd is offline
Exclamation Injector questions.....
1997 F350 7.3 valve cover has CA ID tag
Door says federal standards (verified the PCM is a 1996 Non CA) so AA is what it should have
I have 7 (AA) injectors and 1 (AB) injectors
Never really ran right since I got it seemed to have miss and has gotten worse.
decided to dig in I thought orings or UVH.
passed a buzz test
but when I pull all of the injector plugs except the AB injector it really has a miss (I mean obvious)
when I pull the AB injector plug no change at all? (1 wrong injector?)
Based on my research If it is a CA truck should have AB which are split shot if it is the federal truck such as the door tag says it should have AA injectors which are single shot.
I am thinking I have 1 incorrect injector what do you guys think?
Thanks,
Old 05-19-2013, 01:13 PM
fullsize4wd
also when swapping 1 injector do I still need to worry about hydro locking?
Old 05-19-2013, 03:45 PM
427 fordman's Avatar
427 fordman
427 fordman is online now
You should find out for sure what pcm is in the truck too. Different pcm for cali trucks.
If you swap it fast, as in having one oiled and ready as you pull the other one out, you can do it. I'd clean it out to be sure.
Old 05-19-2013, 03:52 PM
OnDaRoad's Avatar
OnDaRoad
OnDaRoad is offline
Question Changing one injector
So is there a correct procedure to be followed in changing just
one injector ?
Yes there is @ https://www.ford-trucks.com/forums/1...-injector.html
Old 05-20-2013, 08:46 AM
fullsize4wd
So long story short:
1.disconnect all of the UCV's
2.remove old Inj.
3.install new ing w/it being oiled
4.remove the GP
5.crank for a min or so
6.install GP
7.crank a few seconds
8.reconnect the UVC's
9.fire in the hole
Everybody somewhat agree with this for replacement of 1 injector?
Thanks,
Old 05-20-2013, 10:12 AM
superduty4x4's Avatar
superduty4x4
superduty4x4 is offline
Someone could have just replaced the solenoid on that injector, they are all the same and will interchange. But... if you unplug it and it doesn't change the way the truck runs then something is obviously wrong with that injector.
If you want you could swap the AB to a different hole and see if anything changes, that will tell you if its in the wiring or if its the injector itself.
Old 05-20-2013, 10:30 AM
fordpride's Avatar
fordpride
fordpride is offline
What Chase said.
Old 05-20-2013, 10:31 AM
fullsize4wd
Thought the same thing, so I actually already changed the UVC on that side and no change.
Might try swapping the injector that would confirm injector/harness and might rule out bad cylinder
Old 05-20-2013, 10:50 PM
fullsize4wd
Just ordered a new AA injector will try that and keep my fingers crossed.
Old 05-29-2013, 09:59 AM
fullsize4wd
Just wanted to update:
Pulled the mismatch injector here is what I found.
I then put in the new AA injector and man it runs a lot better but still a hick up around the 2200 rpm range. So I think the other o-rings are in similar condition.
So new orings in route for the rest of the injectors as well as a wicked wheel, TS chip, cold air
Old 05-29-2013, 02:47 PM
stainlessstroker95's Avatar
stainlessstroker95
stainlessstroker95 is offline
Glad you found the problem. But the wicked wheel is just a stock replacement for the obs trucks. It only benefits the super duty.
Old 05-29-2013, 03:13 PM
fullsize4wd
that's ok anyways because my current one has some damage to the fins.
Old 06-10-2013, 04:45 PM
fullsize4wd
So I went and replaced the O Rings on all of the other injectors and found some gel like stuff in the injector cups. Normal or is it the diesel gelling from when truck was sitting for period of time prior to me getting it? I plan on running some bio additive I found at Napa to try to clean it up.
johndeerefarmer
2017+ Super Duty
24
07-24-2016 07:13 AM
nghtrgr
12-15-2008 09:45 AM
paintslinga2010
11-16-2008 12:08 PM
pskelton
07-28-2008 05:31 PM
Quick Reply: Injector questions.....
