Vacuum diagram for a 95 F250 w/ 5.8 l engine - Ford Truck Enthusiasts Forums
Old 09-14-2006, 12:23 PM
Ralph_D Ralph_D is offline
Ralph_D is starting off with a positive reputation.
I picked up a 95 F250 with a 5.8 engine. The vacuum lines were disconnected and plugged when I got the truck.
The EGR solonoid (EVR valve) is hooked up correctly with the green line going to the EGR valve and the white line coming from the vacuum plenum.
There are two other valves behind the EVR valve. One side of each valve comes from the vacuum plenum, however, the other 2 lines comming from these valves are discunnected. (yellow & pink)
1) Does anyone know where these connect??
2) Where can I get a detailed vacuum connection diagram?
3) Also, there is no vacuum line connected to the MTA system (Managed Thermactor Air system) Where should this line come from?
Thank you,
Ralph
EVR valve ltyler179 1987 - 1996 F150 & Larger F-Series Trucks 9 01-04-2015 10:55 AM
EGR Vacuum Regulator (EVR) craigdallen 1987 - 1996 F150 & Larger F-Series Trucks 32 10-13-2014 05:28 PM
1999 Ford F250 Super Duty V10 Triton EGR CODE401 mdfudge Modular V10 (6.8l) 2 02-16-2011 11:31 AM
Vacuum/Reservoir/EGR Question GMan1 1987 - 1996 F150 & Larger F-Series Trucks 0 08-15-2009 05:34 PM
EVR testing geodiggr 1987 - 1996 F150 & Larger F-Series Trucks 5 04-24-2009 11:14 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
