Quote:
Originally Posted by mgmoore7
Dannym
I am not sure I follow your post. First you say the aftermarket electric fans are terrible since they don't pull enough CFM and then go on to say that the electric fan is better than the engine driven fan because it pulls more CFM and can be controlled.
This flex-a-lite pulls 4600 CFM when running at 100%. That is more than the Lincoln fan. I don't see how this could be considered terrible. I have not read that anyone is unhappy with a flex-a-lite but have read quite opposite and some have stated that they saw an increase in MPG.
http://www.flex-a-lite.com/auto/html/27inch-electric.html
First off the Lincoln fan is not aftermarket crap, it's a stock vehicle part. I'm saying this fan does have benefits over engine-driven fans.
Perhaps I did over-generalize on the aftermarket stuff. I do believe most of the stuff out there is crap. All I've seen at the parts store have laughable CFM ratings and I recall seeing people here who installed them only to start overheating. But, that certainly doesn't mean a quality part can't be in the aftermarket.
They're misrepresenting it as a 27" fan. A dual 13.5" is 364.5 sq in, which only a bit higher than the 18" Lincoln Mk VIII's 324 sq in. But, if it pulls 4600 CFM that's not bad at all. I'd use it. In fact being a bit more spread out like this might give it better cooling for the CFM.
