Removal of ignition cylinder
Old 07-12-2001, 09:34 AM
Blue65's Avatar
Blue65
Blue65 is offline
Hey everyone! I am removing all of the dash ***** and bezels from my '65 F100 so the dash can be painted. I have all of them off except for the ignition switch bezel. Can someone tell me how to remove the ignition switch bezel? Thanks, Steve.
Old 07-12-2001, 09:47 AM
skip4274's Avatar
skip4274
skip4274 is offline
With the key in the ignition, turn the switch to the accessory position. Put a paper clip in the little hole above the key (all the way in). Push the lock set in and turn the key past the accessory location until it releases and then it will pull out of the switch. Don't break the key!!!!!!
Skip4274
4everFord
Old 07-12-2001, 10:39 AM
Rosati's Avatar
Rosati
Rosati is offline
Removal of the Bezel is easy but can really be a pain if you break the bezel.
Reach up under the dash and grab the switch housing. Push it very hard toward the rear of the cab while turning the bezel counterclockwise. you should feel the bezel "click" loose. then pull and rock gently on the switch housing until it pulls free.
Take care not to bend the tangs on the bezel or break one of the pins on the housing.
Good Luck,
Krosati
Old 07-12-2001, 07:44 PM
jowilker's Avatar
jowilker
jowilker is offline
Steve, Do what Skip said first, after you get the cylinder out, you can remove the bezel as krosati said. The key must be horizontal and off on the bezel vertical before the cylinder will come out, if it will come at all. I had to drill my last one to get the bugger out.
With your left hand holding the bezel, reach behind with your right push forward and counter clockwize and it should come apart.
John
jowilker
[link:www.ford-trucks.net/users/jowilker|Club FTE since 01 01] My FTE Page
[link:www.ford-trucks.net/users/jowilker/NCFTE.html|NC Truck Owners] NC Ford Truck owners group
66F100s Rule
In the cool still quiet of night you can hear chevies rusting away.
Old 07-13-2001, 02:58 PM
FTE Ken's Avatar
FTE Ken
FTE Ken is offline
Shadowrider123
12-16-2012 05:46 PM
steekers
06-03-2011 11:21 PM
tompmatthews
12-02-2009 11:46 AM
tompmatthews
11-25-2009 01:19 PM
jethro1
04-08-2004 06:30 AM
Quick Reply: Removal of ignition cylinder
