I have a power point hooked to upfitter switch #1. I plugged a second item into the bank of power points I have installed and it quit working(seems like a fuse blown). The pilot light on the end of the switch still works. I found the 30 amp fuse in the fuse pannel, it seems fine.
Could someone give me direction in trouble shooting this problem?
I did find the problem after checking all else. There was a hidden 15 amp glass fuse inside the plug of the addon powerpoint setup. I just cut it off and spliced right to the upfitter wire for switch one since it is fused for 30 amps.
