Champion plugs?
Old 09-14-2006, 09:24 PM
tgore3's Avatar
tgore3
tgore3 is offline
Man, I done opened a whole can of worms
It's cool to read everyone's opinions and experiences though. I do like the looks of those Champion truck plugs. They've got to be the best looking plug on the market IMO. Not just the same old black and white spark plug.
Nobody has used the truck plugs? That seems surprising. I would've tried them had they been in stock, just for kicks since I've never used Champs in anything with more than 1 cylinder. The NGK V-powers are still doing good so far.
Here's what Champion says about thier truck plugs
"Truck Plugs are engineered specifically for pickups, SUV's and vans. A massive copper core center electrode has over 120% of the spark area of conventional plugs lending toward a longer life in heavy duty performance needs. The copper core ground electrode dissipates heat faster than a conventional plug. A black glazed zirconia enhanced ceramic insulator offers 40% more strength for durability under rough driving conditions"
It is a sexy spark plug at least
Old 09-17-2006, 12:13 AM
"Beemer Nut"'s Avatar
"Beemer Nut"
"Beemer Nut" is offline
Careful, anything related to sexy will cost your be it your wife or a hired dinner companion.
What's the asking price for them puppies, they come in the heat range for FE's?
.....=o&o>.....
Old 09-17-2006, 09:31 AM
tgore3's Avatar
tgore3
tgore3 is offline
.....=o&o>.....
LOL
Looks like p/n 4018 is for the FE, about $2.90 per. No idea what heat range that is.
Old 09-19-2006, 06:39 AM
Cool1996's Avatar
Cool1996
Cool1996 is offline
I have used champion plugs in everything i own and have never once had a problem with them. they are in both of my trucks, my lawnmowers, my motorcycle and anythign that takes a spark plug at my house has champions. i personally have never had good luck with ngk in my motorcycles (2 or 4 stroke) they have left me back in the woods more then once and ill never buy another one
Old 09-19-2006, 11:20 PM
"Beemer Nut"
I have found Champs will split the porcelain around the center elecrtrode if any "light" detonition has been subjected to the plug, also if you have lumbered around town for a week then jumped on it hard on the on ramp they can short out at the center electrode porcelians unless you ease into the power and burn off the carbon slowly vs other brands. This is with the correct fuel / air ratio and heat range.
Seems Champs have a narrower operating heat zone, lumbering around town or 30 seconds at 5,200 in the 125+ mph zone. It seems I can exceed the heat zone range vs other brands but I won't change over. Like I posted before I pressure spark test them in the Champion Plug Tester before installing and haven't had a problem with the ones that passed, a a few have failed even when new.
At 40+ years still a Champ user but I understand how to weed out the bad and drive with them with great results. Stuck on Champs, JMO's.
.....=o&o>.....
Old 09-20-2006, 10:19 AM
sysman_rick's Avatar
sysman_rick
sysman_rick is offline
Angry
If any of you have a 5.4 l 3-v engine,be careful. There is a problem with plug failure when removing the plug(s).
Old 09-20-2006, 05:54 PM
tgore3's Avatar
tgore3
tgore3 is offline
Didn't they have some problems with some 4.6's blowing spark plugs out of the motor too?
Those modulars are a pain to change plugs. I had a 97 with a 4.6 and it was rediculous. Took me like 3 hours.
Old 10-19-2006, 09:33 AM
irocknrol2's Avatar
irocknrol2
irocknrol2 is offline
For years everyone would use champion plugs in a ford an of course AC delco in a general motors car. The interesting thing is AC stands for Albert Champion, the maker.
Old 10-19-2006, 06:04 PM
kotzy's Avatar
kotzy
kotzy is offline
Funny isn't it Chevrolet brothers lost their car and name to the scoundrels at Gm and they latched onto AC for what he could gain them. One more observation of the previous post someone mentioned rolled threads on the shell of a plug, I believe that
all the makers have gone to that.
Old 10-31-2006, 10:46 AM
77460f150's Avatar
77460f150
77460f150 is offline
Champions are only for lawn mowers and Chrysler products. AC is for GM, Motorcraft or Autolite for Ford and NGK for imports. My .02 cents. -Ed
Old 10-31-2006, 06:28 PM
captchas's Avatar
captchas
captchas is offline
Guest
i have auto light in my wifes jeep liberty and it runs better then the factory nipons.
i personally have found most american brand cars run very well with autolight even the gm engines in my small boat. for my fords motorcraft or autolight only.
77460f150 funny thing even my lawn mowers run good on autolight. what do have the best universal plug made to run in our fords ? seems that way to me as i have been useing them this way since 1964 when ford still owned the autolight brand name
Old 11-02-2006, 03:17 PM
Lee250's Avatar
Lee250
Lee250 is offline
I recently changed the plugs on my moms caravan. Took champion plugs out after 180,000 miles. Yes those were the original plugs and even after 180,000 miles some of them were still in okay condition.
  #28
Old 11-02-2006, 09:00 PM
Netfly's Avatar
Netfly
Netfly is offline
I've never had good luck with Champion. They foul out very easily. In motors that burn a little oil, I've seen Autolite last for years where the Champion would foul out in a minute. Autolite is now made by Honeywell and the Motorcarft brand is the same stuff. Go for the Double Platinum version if you want their best.
  #29
Old 11-03-2006, 12:18 AM
"Beemer Nut"
Replies on Champion's make 'em sound like they're one step up from dog waste, if that bad wouldn't they of gone out of business 30 years ago?
  #30
Old 11-03-2006, 12:33 AM
Netfly's Avatar
Netfly
Netfly is offline
30 or maybe 40 years ago they were hailed at the track as having the best spark. For 1/4 mile that's fine, but as far as I'm concerned they were never a great everyday plug. When a bad mixture hit them they foul. Meanwhile Autolite would advertise that they could burn in oil and they did. Now years later I'm sure their new plugs have changed, but I haven't tried them.
Quick Reply: Champion plugs?
