Block heater powered by solar power???
Old 09-12-2006, 06:05 PM
mmmPowerStroke's Avatar
mmmPowerStroke
mmmPowerStroke is offline
Since winter is coming and I don't have a place to plug my truck into I was wondering if they make a solar powered block heater. I've seen a solar powered battery charger at ford once it was caked with dust and I think it was only like $50. If this device isn't out their I think it would be a great thing to make.
Old 09-12-2006, 06:11 PM
dcf4x4's Avatar
dcf4x4
dcf4x4 is offline
That interests me so much that I am passing on supper (actually just delaying it alittle) just to look up the logistics. I don't think anyone actually makes something suitable but I think a solar panel and deep cycle battery set on some sort of timer would work well. One draw back would be the actual output of the solar panel during winter... not sure how well it would actually work.
Old 09-12-2006, 06:13 PM
ssnh's Avatar
ssnh
ssnh is offline
my block heater is 1500 watts
i'd need 8 of these - http://www.wholesalesolar.com/produc...E/GEPV200.html
Old 09-12-2006, 06:52 PM
dcf4x4's Avatar
dcf4x4
dcf4x4 is offline
ok, so roughly 1500 watt draw. Brief research tells me solar panels run 6 watts/sqft on a good day. No idea if that is correct but it's a starting point.
Surface area of the hood and CC roof is 5.5x8.5 which is 46.75 sqft which is 320 watts continuous (on a great day). Dump that into 2 deep cycle batteries and then figure you need to run the heater for 2 hours every morning and... um... I just reached the limit of my knowledge. Not sure where to go next.
I would imagine you could buy a 2000 watt inverter to run off the batteries.
OR!
charge the deep cycles off your special built souped up alternator with only rooftop panels as back up. (cuts down on tackiness since no one can see the roof anyway)
either way, those two batteries would fit in the space along the frame under the bed with the inverter in the cab on the rear wall to use the heat output to warm the interior.
Feel free to correct or augment this idea. I'm tempted to try it out.
Old 09-12-2006, 07:30 PM
Uzumati's Avatar
Uzumati
Uzumati is offline
Dont forget that if your heater draws 1500 watts running its initial peak start up draw is closer to 3000 watts. This is only a spike drain but if you cant provide for the spike you can in effect cause a "brown out" and damage the heater element.
Old 09-20-2006, 10:19 PM
mmmPowerStroke
I guess I will have to look at other options.
Old 09-21-2006, 08:43 PM
rjmay's Avatar
rjmay
rjmay is offline
How does resistance heat (load) draw more electical amps during start up?
Old 09-22-2006, 10:12 AM
nlemerise's Avatar
nlemerise
nlemerise is offline
Theoretically possible to do, but practically impossible. My house has a hybrid system (both utility and solar power) and I can tell you that my panels which are about 4 feet long and 20" wide provide 70 watts at full sunlight, perpendicular to the sunlight. So for direct application you would need 20-30 of these panels at $400-$450 per panel . Of course you could build a system to charge deep cycle batteries (as I have - a 24 volt system), then hook an inverter to it...I can tell you that I have eight - 3' tall deep cycle batteries and a Trace inverter that could do the job, but it would kill the batteries in short order.
If I was away from AC and I needed to preheat the engine I'd get a diesel fuel powered preheater...I had one on my heavy truck years ago. Worked great!
Old 06-27-2022, 08:06 AM
Listor's Avatar
Listor
Listor is offline
This is an interesting idea, although unless you're in subzero temps i just can't see the practicality or cost effectiveness, with a proper working glow plug system you should have all you need.
other things to do to help your gp's change to 5/30 oil for the winter months or start a little fire under the truck!
Old 06-27-2022, 12:01 PM
Bitterroot Diesel's Avatar
Bitterroot Diesel
Bitterroot Diesel is offline
Former Vendor
Webasto heater is the way to go.
Old 06-27-2022, 08:05 PM
callforfire's Avatar
callforfire
callforfire is offline
This is the way. After moving to MT, plugging in my block heater was eating my lunch on my electric bill. And there were times when it just couldn't keep up with being soaked in the negatives all night
I scored an open box webasto on ebay and that thing paid for itself in the first winter. I also don't have to let her idle while I'm in the store or something. saves on wear and fuel.
Old 06-27-2022, 09:40 PM
Kwikkordead's Avatar
Kwikkordead
Kwikkordead is online now
The title of this thread makes me think that it will only be viable when you need it the least, not the most.
Torklift Sheryl
Vendor Specials, Discounts, Product Announcements & Group Buys
12-20-2016 07:10 PM
Torklift Sheryl
11-08-2016 02:33 PM
Torklift Sheryl
07-19-2016 01:01 PM
Torklift Sheryl
07-24-2015 10:24 AM
Torklift Sheryl
06-29-2015 10:28 AM
Quick Reply: Block heater powered by solar power???
