HPOP Leak Help
HPOP Leak '97 F-250
So where is everyone typically getting these leaks? I changed the gaskets and put on new O-rings, but I didn't buy Fords $40 ones. Well I still have the leak and I can't tell where it's coming from. Just wondering where everyone else was getting their leaks. Thanks. '97 F-250 PSD
Can you give us a little more information on here the leak is, when it leaks, where you see the oil, etc. The more info that we have the better someone can help. Are you sure it's oil and not diesel fuel? Is the leak in the valley, front of the engine, on one head, etc.? What o-rings did you replace? Have you checked the o-rings on the IPR?
