Wont come out of 4x4
i have an 04 f350 6.0 and used my four wheel drive and now it wont come out. i have the electric shift on fly. I have no power to the transfer case and have no blown fuses. Somebody told me to ckeck the 4x4 module but i cant find it and nobody at ford will tell me where it is. I have tried all the backing up and driving forward all of that it just wont come out. Looking for help if anyone has any ideas thanks
on
Welcome to FTE and the 6.0 forum BrodyJ29
When you get a chance you might want to cruise over to our Tech Folder for some great 6.0 info.
https://www.ford-trucks.com/forums/showthread.php?t=303583
Please take a few moments to read our site guidelines as well.
https://www.ford-trucks.com/guidelines.html
Here's a Ford Broadcast Message that might help but, I am not exactly sure where the relays are located
ESOF Transfer Case Concerns:
On some trucks with the electronic shift-on-fly transfer case there may be engagement/shift concernes. Check the ESOF motor relays on the driver side fender. If the relays or relay box have become dislodged, corrosion may form on the relay terminals or inside the relays. Broadcast Message 1511
Could be a vacuum problem as well. Hopefully our tech will be online tonight to help.
Good luck.
Good luck.
rlebar
02-13-2014 05:27 PM
Wobe72
10-26-2006 05:14 PM
n2o88
03-18-2004 03:21 PM
