Ford F-150 spare tire under bed carrier
Conanski...
you're right, they do suck, but if you use your truck as a truck, taking the tire out of the bed every time is also a PITA.
BTW, you can extend the depth of the tire carrier by cutting off the old pieces, and welding in 5/8" round stock to extend the length for wider tires.
Considering how mine (doesn't) fits, I imagine larger diameter tire within reason would fit also.
I still say the best tire carrier for the F-series is the full size bronco carrier. That reminds me, I need to install mine one of these days.
National Parts Depot will send you a free catalog with those parts and a lot of other good stuff. I just ripped all of that stuff off my 96 after I had to change a tire one morning before work. Someday if I ever decide to put it back I'll probably fabricate my own threaded rods that are about 2-in shorter, replace the seized/cross-threaded U-nuts and tack weld the center tire keeper bolt to keep it from spinning. Also some never-seize and a plastic grease-loaded cap on top of the threaded ends might be a good idea to help keep out all the crud and rust. They do keep the tire out of the way, but aren't very handy unless you have a flat/blowout in your driveway. In the mud/snow they would be a PITA. My 2 cents.
TheSterling
13
05-31-2018 10:06 AM
Gertie-The '49 F2
37
10-29-2015 04:45 PM
lamenytro
03-17-2011 10:37 PM
Jamouneau
17
03-24-2006 03:32 PM
