Ford F-150 spare tire under bed carrier - Ford Truck Enthusiasts Forums
Old 09-11-2006, 03:52 PM
bf5113 bf5113 is offline
bf5113 is starting off with a positive reputation.
The under bed spare tire carrier on my '93 truck has just about rusted away. I want to buy a replacement (threaded rods and metal bar) but I'd rather not go to a dealer or a junk yard. Any suggestions?
Old 09-11-2006, 05:04 PM
Conanski's Avatar
Conanski Conanski is online now
Conanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant future
I hate those things!!! I have removed them from every truck I have owned because they rust out, seize up, and won't hold a tire larger than the factory size. My spare has been riding in the bed since day 1, where it stays clean!!!
Old 09-11-2006, 05:09 PM
quicklook2's Avatar
quicklook2 quicklook2 is offline
quicklook2 has a very good reputation on FTE.quicklook2 has a very good reputation on FTE.quicklook2 has a very good reputation on FTE.quicklook2 has a very good reputation on FTE.
go to left column and find national parts depot. they have them.
Old 09-11-2006, 06:59 PM
frederic's Avatar
frederic frederic is offline
frederic is a name known to allfrederic is a name known to allfrederic is a name known to allfrederic is a name known to allfrederic is a name known to allfrederic is a name known to all
Conanski...
you're right, they do suck, but if you use your truck as a truck, taking the tire out of the bed every time is also a PITA.
BTW, you can extend the depth of the tire carrier by cutting off the old pieces, and welding in 5/8" round stock to extend the length for wider tires.
Considering how mine (doesn't) fits, I imagine larger diameter tire within reason would fit also.
I still say the best tire carrier for the F-series is the full size bronco carrier. That reminds me, I need to install mine one of these days.
Old 09-12-2006, 12:14 AM
wildcat99's Avatar
wildcat99 wildcat99 is offline
wildcat99 is starting off with a positive reputation.
National Parts Depot will send you a free catalog with those parts and a lot of other good stuff. I just ripped all of that stuff off my 96 after I had to change a tire one morning before work. Someday if I ever decide to put it back I'll probably fabricate my own threaded rods that are about 2-in shorter, replace the seized/cross-threaded U-nuts and tack weld the center tire keeper bolt to keep it from spinning. Also some never-seize and a plastic grease-loaded cap on top of the threaded ends might be a good idea to help keep out all the crud and rust. They do keep the tire out of the way, but aren't very handy unless you have a flat/blowout in your driveway. In the mud/snow they would be a PITA. My 2 cents.
Old 09-12-2006, 09:02 AM
quicklook2's Avatar
you can download a pdf version of the npd catalog from thier site.
Old 09-12-2006, 09:12 AM
jas88's Avatar
jas88 jas88 is offline
jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.
I've got one on a parts truck. $20 plus shipping, rust free from Texas truck.
78-79 bronco spare tire carrier on 73-79 f150? TheSterling 1973 - 1979 F-100 & Larger F-Series Trucks 7 06-11-2016 10:18 AM
Spare Tire Carrier gfpilot 1961 - 1966 F-100 & Larger F-Series Trucks 3 12-16-2015 10:19 AM
Need Spare Tire Carrier and Hardware for F-2 Gertie-The '49 F2 1948 - 1956 F1, F100 & Larger F-Series Trucks 37 10-29-2015 04:45 PM
WTB-1992-1997 under bed spare tire carrier set Leggeman01 WTB - Parts & other 2 07-10-2015 06:27 PM
1960 F100 Spare Tire Carrier murphy 1948 - 1956 F1, F100 & Larger F-Series Trucks 6 08-18-2005 01:01 PM
Tags
150, 1990, 1997, 1998, 2002, bed, carrier, f150, ford, holder, spare, tire, truck, underbed, winch
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
