97 F150 Wiring diagram/electrical issues - Ford Truck Enthusiasts Forums
Old 09-11-2006, 02:50 PM
seacapt seacapt is offline
seacapt is starting off with a positive reputation.
I'm new to the forum and look forward to digging through all of the info on here.
Here are my issues. I have a 97 F150 and have had an intermittent problem with the electrical system. If someone could direct me to a wiring diagram I would appreciate it (I tried to search it here without success).<O
Here's what's going on. Every now and then the power windows and wipers won't work. From what I can tell they are on separate circuits but it always seems to happen together. Once it happens I can turn the truck off and restart it and it usually clears up the problem. But some days (like today in the rain) it doesn't. Like I said if I notice one not working the other always checks bad as well but the wipers will come and go without the windows coming back online. I can hear what sounds like a relay click on the dash fuse panel and I know the windows are working again and then I hear the relay again and they don't work. Looking at the fuses I don't see that they have anything in common but I've never had one fail and the other keep working
Anyone with any thoughts on this would be appreciated.<OThanks,<OAl<O
Old 09-12-2006, 01:37 PM
Franklin2's Avatar
Franklin2 Franklin2 is offline
Franklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant future
What the power windows and wipers have in common is the GEM module. It's located under the dash towards the left side. It looks like a black box with lots of wires. Check that area out and see if you have any water damage. When it rains, do you notice any water under the dash? Sometimes the windshield leaks, and runs right down into the GEM module, corroding it and making it fail.
If you need a diagram, see if www.helminc.com has any in stock.
65 f100 wiring diagram SC65F100 1961 - 1966 F-100 & Larger F-Series Trucks 14 01-14-2013 05:45 PM
Offenhauser intake which carberator and kits starwriter Ford Inline Six, 200, 250, 4.9L / 300 10 01-28-2008 03:12 AM
1990 Bronco II Questions ZeroBoyWD Bronco II 4 01-15-2008 08:37 PM
Back Window Not Working mccandyce 1978 - 1996 Big Bronco 11 10-12-2007 08:07 PM
61 Unibody headliner questions Corbetts_Auto 1961 - 1966 F-100 & Larger F-Series Trucks 3 02-03-2007 04:19 PM
Tags
150, 1997, 2003, 97, dashboard, diagram, elcrical, electrical, f150, ford, fseries, fuel, problem, truck, wiper, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
