2003 6.0 NO START CODES p0263, p0266, p0269, p2290, p2291, p2617, p2623
Please HELP!!! My 2003 powerjoke 6.0 stalled the other day and will not start. I pulled codes p0263, p0266, p0269, p2290, p2291, p2617, p2623. I have fuel and can hear the pump running. Truck is completely stock. I need Ideas.
Thanks Ryan
Thanks Ryan
Wow, that's a lot of codes. You have cylinder contribution/balance codes for cylinders 1, 2, and 3. You have two low ICP pressure codes and a crank positon sensor code. You have either a high pressure oil leak or a failed HP pump, or IPR valve. I haven't actually seen to many bad IPR valves so I would lean toward the HP leak or HP pump. Another possibility is no base oil pressure. Better tow it to a dealer.
when me and canada were talking about harnesses the codes were for circuit low. contribution codes is skip or losing oil.
another idea is what kind of oil and weight are you using. had a few trucks that had the wrong weight for the climate they were in. also check the oil level, cause your icp could have puked oil and you could be low.
gesb123
1999 to 2016 Super Duty
10-29-2014 08:46 AM
