2005 Escape Transaxle lube?
I am planning on changing the lube in the Transaxle of my 2005 Escape with the 2.3L Duratech engine and 5 speed manual transaxle. I am having a hard time finding a lube that meets the Ford spec"WSS-M2C203-A1" I also would like to use a synthetic lube. Ford lists the part number as "F32Z-19C547–MA" GL4 gear lube in the owners manulal.
I did see that Amsoil makes a product called MTG that is for this purpose, how do I know if it meets Ford spec? I a better lube available that does not cost over $10.00 a quart?
Thanks Dan
Thanks Dan
Originally Posted by ford390gashog
well the spec for the trans axle is just plain mercon ATF. never use the GL4 in that unit , you must be reading it wrong as the GL4 is for the rear differential and not for the transmission.
Dan
edit
This is copied from the maintenance and specifactions sheet in the owners manual.
Manual transaxle Motorcraft SAE
75W-90 Gear Oil
Part #"F32Z-19C547–MA" Spec "WSS-M2C203-A1"
under the sheet that lists the refil capacity it says"Transmission
fluid
Motorcraft SAE
75W-90
API GL-4 Gear
Oil
Manual transaxle
(2WD)
2.4 quarts
(2.3L) "
FWIW, you can look up the Motorcraft lubes for manual trannys at http://www.fcsdchemicalsandlubricant...f/mantrans.pdf
Steve
Steve
Crimson
1997 - 2003 F150
07-17-2016 09:27 AM
