8 Lug Wheels for E350
Old 09-10-2006, 10:18 AM
carrfamilynj's Avatar
carrfamilynj
carrfamilynj is offline
I noticed there's not a whole lot of nice ones to choose from, unless I'm looking in the wrong places. Anyone got a good source for them?
Old 09-10-2006, 01:32 PM
maples01's Avatar
maples01
maples01 is offline
I bought a set of black wagon wheels from PepBoys 4 years ago, just a simple wheel, nothing fancy, I'd liketo have some shiny aluminum ones now, but can't afford them.
Old 09-10-2006, 01:50 PM
rebocardo's Avatar
rebocardo
rebocardo is offline
The alloys (16.50 x 10 - 8x6.50) cost $159 brand new.
I just bought a used set of four tires and rims off www.craigslist.org just to get the tires (33s) and I plan on E-BAYing the rims because I prefer steel rims off road.
After comparing the two, I say the steel rims probably weight 20+ pounds more and with larger tires that weight adds up. Though on a 6-7K pound van that is like drinking a diet soda with a Big Mac.
The alloys do look much nicer then the steel and chrome, even when new.
Old 09-10-2006, 03:53 PM
carrfamilynj
Are the rims 8 lug Ford rims? I need 8 X 170
Old 09-10-2006, 06:41 PM
al_e._gator's Avatar
al_e._gator
al_e._gator is offline
carrfamilynj, you DO NOT need 8 X 170mm rims for an E350 unless you have a 4X4 conversion. Vans use 8 X 6.5", Super Duty trucks use 8 X 170mm. Rims from GM and Dodge 3/4 and 1 ton vehicles are 8 X 6.5" and will fit. Make sure any rims you buy are rated for your max load.
Old 09-10-2006, 08:40 PM
maples01's Avatar
maples01
maples01 is offline
I thought the newer vans recieved the metric bolt pattern like the trucks, no I haven't checked my 99 E-350 with a 99 F-350 wheel yet.
Old 09-11-2006, 06:50 AM
rebocardo's Avatar
rebocardo
If you really need 8 x 170 mm. these rims are all over E-Bay for sale.
Old 09-11-2006, 03:57 PM
al_e._gator
I guarantee a 2004 E350 is 8 X 6.5". I have been looking for a good set of alloys for months.
Old 09-11-2006, 04:12 PM
carrfamilynj
Yea, so I guess the full-size vans stayed SAE, and the SD trucks went metric?
Between craigslist and ebay, there's definitely plenty of wheels out there, especially in the 8 X 6.5 size. Just gotta watch the backspacing.Speaking of which, what is it on these vans?
Old 09-12-2006, 07:28 PM
mhg's Avatar
mhg
mhg is offline
check out jegs
a good selection
good prices and
free shipping
Old 09-13-2006, 09:06 AM
rebocardo's Avatar
rebocardo
http://www.tyres1.com/
Nice alloys 16.50 x 9.75 with 8 x 6.5 are $159 new.
Old 09-13-2006, 03:37 PM
carrfamilynj
Weight Capacity?
For a 2004 E350 extended(15 pass), what does the weight capacity for each wheel need to be?
Old 09-13-2006, 05:02 PM
al_e._gator
From your door sticker, your rear gross axle weight rating is 6084 lbs. That means that each of your tires and rims need to be rated for at least 3042 lbs
Old 09-14-2006, 04:51 PM
rebocardo's Avatar
rebocardo
Well, knowing that it is an extended E-350 changes what you should get for a tire and rim if you are loading it with passengers.
Assuming you are from NJ, you want something good in snow and passable in ice that can handle potholes.
You want to get a 16" and NOT a 16.50" rim. In a blowout a 16.50 will not stay on the rim at all and that could be fatal in a loaded 15 pass. van.
You want at least Load Range E from an OEM with a history of good tire sidewalls.
A nice tire:
Michelin LTX A/T
245/75 RR16
120/116R E
3042 lbs.
http://www.tirerack.com
Read the reviews, very favorable, tires last.
Havecooker
1999 to 2016 Super Duty
04-09-2017 11:07 AM
Jaime74656
12-25-2015 08:53 AM
wpnaes
07-15-2013 09:18 PM
Trulyvintage
1947 and Older Ford Trucks
05-20-2011 10:40 AM
jasonschwenk
New York Chapter
11-27-2006 07:35 AM
Quick Reply: 8 Lug Wheels for E350
