8 Lug Wheels for E350 - Ford Truck Enthusiasts Forums
1968-2013 Full Size Vans Econolines. E150, E250, E350, E450 and E550
Old 09-10-2006, 11:18 AM
carrfamilynj's Avatar
carrfamilynj carrfamilynj is offline
carrfamilynj is starting off with a positive reputation.
I noticed there's not a whole lot of nice ones to choose from, unless I'm looking in the wrong places. Anyone got a good source for them?
Old 09-10-2006, 02:32 PM
maples01's Avatar
maples01 maples01 is offline
maples01 has a good reputation on FTE.maples01 has a good reputation on FTE.maples01 has a good reputation on FTE.
I bought a set of black wagon wheels from PepBoys 4 years ago, just a simple wheel, nothing fancy, I'd liketo have some shiny aluminum ones now, but can't afford them.
Old 09-10-2006, 02:50 PM
rebocardo rebocardo is offline
rebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud of
The alloys (16.50 x 10 - 8x6.50) cost $159 brand new.
I just bought a used set of four tires and rims off www.craigslist.org just to get the tires (33s) and I plan on E-BAYing the rims because I prefer steel rims off road.
After comparing the two, I say the steel rims probably weight 20+ pounds more and with larger tires that weight adds up. Though on a 6-7K pound van that is like drinking a diet soda with a Big Mac.
The alloys do look much nicer then the steel and chrome, even when new.
Old 09-10-2006, 04:53 PM
Are the rims 8 lug Ford rims? I need 8 X 170
Old 09-10-2006, 07:41 PM
al_e._gator's Avatar
al_e._gator al_e._gator is offline
al_e._gator is starting off with a positive reputation.
carrfamilynj, you DO NOT need 8 X 170mm rims for an E350 unless you have a 4X4 conversion. Vans use 8 X 6.5", Super Duty trucks use 8 X 170mm. Rims from GM and Dodge 3/4 and 1 ton vehicles are 8 X 6.5" and will fit. Make sure any rims you buy are rated for your max load.
Old 09-10-2006, 09:40 PM
maples01's Avatar
I thought the newer vans recieved the metric bolt pattern like the trucks, no I haven't checked my 99 E-350 with a 99 F-350 wheel yet.
Old 09-11-2006, 07:50 AM
If you really need 8 x 170 mm. these rims are all over E-Bay for sale.
Old 09-11-2006, 04:57 PM
I guarantee a 2004 E350 is 8 X 6.5". I have been looking for a good set of alloys for months.
Old 09-11-2006, 05:12 PM
Yea, so I guess the full-size vans stayed SAE, and the SD trucks went metric?
Between craigslist and ebay, there's definitely plenty of wheels out there, especially in the 8 X 6.5 size. Just gotta watch the backspacing.Speaking of which, what is it on these vans?
Old 09-12-2006, 08:28 PM
mhg mhg is offline
mhg is starting off with a positive reputation.
check out jegs
a good selection
good prices and
free shipping
Old 09-13-2006, 10:06 AM
http://www.tyres1.com/
Nice alloys 16.50 x 9.75 with 8 x 6.5 are $159 new.
Old 09-13-2006, 04:37 PM
Weight Capacity?
For a 2004 E350 extended(15 pass), what does the weight capacity for each wheel need to be?
Old 09-13-2006, 06:02 PM
Quote:
From your door sticker, your rear gross axle weight rating is 6084 lbs. That means that each of your tires and rims need to be rated for at least 3042 lbs
Old 09-14-2006, 05:51 PM
Well, knowing that it is an extended E-350 changes what you should get for a tire and rim if you are loading it with passengers.
Assuming you are from NJ, you want something good in snow and passable in ice that can handle potholes.
You want to get a 16" and NOT a 16.50" rim. In a blowout a 16.50 will not stay on the rim at all and that could be fatal in a loaded 15 pass. van.
You want at least Load Range E from an OEM with a history of good tire sidewalls.
A nice tire:
Michelin LTX A/T
245/75 RR16
120/116R E
3042 lbs.
http://www.tirerack.com
Read the reviews, very favorable, tires last.
Wanted Truckin23 1948 - 1956 F1, F100 & Larger F-Series Trucks 4 10-06-2014 09:20 PM
delete Myfreeford 1973 - 1979 F-100 & Larger F-Series Trucks 36 08-17-2014 10:24 PM
10 years! jseim44 Nebraska Chapter 8 04-29-2014 09:07 AM
300 I-6 rogwelch 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 9 02-13-2000 12:29 AM
Tags
atlanta, backspacing, craigslist, e350, ga, lug
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
