axle codes? - Ford Truck Enthusiasts Forums
axle codes?
Old 09-09-2006, 09:35 PM
abcat12 abcat12 is offline
abcat12 is starting off with a positive reputation.
axle codes?
I cant find any website that talks about 80's 9" rear axle code tags. this is what mine says I think
E A 2B05
50 9 S319B
can anyone put that in english? Its on an 82 f150
thanks
Old 09-10-2006, 01:56 AM
sierraben's Avatar
sierraben sierraben is offline
sierraben has a spectacular reputation.sierraben has a spectacular reputation.sierraben has a spectacular reputation.sierraben has a spectacular reputation.sierraben has a spectacular reputation.sierraben has a spectacular reputation.sierraben has a spectacular reputation.sierraben has a spectacular reputation.sierraben has a spectacular reputation.sierraben has a spectacular reputation.sierraben has a spectacular reputation.
I think there's a label on the driver's side door opening that has a rearend code (at least on an '81).
That code would most likely give you the info you need.
Just post that code and someone will most likely have the info.
Old 09-10-2006, 10:29 AM
82F100SWB's Avatar
82F100SWB 82F100SWB is offline
82F100SWB has a very good reputation on FTE.82F100SWB has a very good reputation on FTE.82F100SWB has a very good reputation on FTE.
You're missing the first numbers on the left hand side. But, I can tell you that you have a 3.50 geared 9", 3.50 is the only factory 9" ratio that ends in 50.
Old 09-13-2006, 07:59 PM
it says H6 in the jam
Old 09-13-2006, 08:21 PM
Dungeon_Master's Avatar
Dungeon_Master Dungeon_Master is offline
Dungeon_Master is gaining momentum as a positive member of FTE.
Limited Slip:
Code...........Man...Size.......GVW....Gear Ratio
H6.............Ford......................3750..... ..3.50
Old 09-13-2006, 08:22 PM
sierraben's Avatar
H6: limited slip rear
3750 lb. rating
3.50 ratio
That's what it shows in my 81 book
Old 09-14-2006, 10:05 PM
tgore3 tgore3 is offline
tgore3 is starting off with a positive reputation.
Already been answered, but I did finally find a chart for these trucks the other day for another thread. Here it is again just for kicks. Wish mine said H6, mine's the 16.
Ford Rear axle codes used from 1981-1986
13- Ford 9" 2.75 ratio 1981-83
13- Ford 8.8 4.11 ratio 1985-86
H3- Ford 9" ls 2.75 ratio 1981-82
H3- Ford 8.8 axle 4.11 ratio with limited slip 1985-86 (3800 pound)
14- Ford 9" 3.00 1981-1986
H4- Ford 9" 3.00 Limited slip diff 1981-86
15- Ford 9" 3.25 1981-82 and 2.73 in 1983
H5-Ford 9" 3.25 limited slip 1981-82 and 2.73 in 1983
16- Ford 9" axle 3.50 ratio (3750 pound)verified
H6- Ford 9" axle 3.50 ratio with limited slip (3750 pound)verified
18- Ford axle 8.8 3.08 ratio (3800 pound) 1983-86verified
H8- Ford axle 8.8 3.08 ratio limited slip (3800 pound) 1983-86verified
19- Ford axle 8.8 3.55 ratio (3800 pound) 1983-86verified
H9- Ford axle 8.8 3.55 ratio with limited slip (3800 pound) 1983-86verified
23- Dana 60-3 axle 3.54 ratioverified
24- Dana 60-3 axle 3.73 ratio verified
29- Ford Semi Float Sterling 10.25, 3.55 ratio
B9- Ford semi Float Sterling 10.25, 3.55 ratio limited slip diff
B5-Ford semi Float Sterling 10.25, 4.10 ratio limited slip diff
39- Ford full float Sterling 10.25 3.55 (single rear wheel)
C9- Ford full float Sterling 10.25 3.55 (single rear wheel) with limited slip diff
35- Ford full float Sterling 10.25 4.10 (single rear wheel)
C5- Ford full float Sterling 10.25 4.10 (single rear wheel) with limed slip diff
33- Dana 61-1 3.54 ratioverified
C2- Dana 61-1 3.54 ratio with limited slip diffverified
52- Dana 70-1 HD 4.10 ratio (8700 rating)verified
53- Dana 70-1 HD 3.54 ratio from 1983-86 (4.56 in 1982) (7400 rating)verified
E2- Dana 70-1 Hd 4.10 ratio with limited slip diffverified
49- Ford Sterling 10.25 dual rear wheel 3.55 ratio (7400 rating)verified
D5- Ford Sterling 10.25 dual rear wheel 4.10 with limited slip diff (7400 rating)
69- Ford Ford Sterling 10.25 dual rear wheel 3.55 ratio (8250 rating)
F5- Ford Ford Sterling 10.25 dual rear wheel 4.10 ratio limited slip (8250 rating)
Old 09-22-2006, 02:04 PM
ClydeSDale's Avatar
ClydeSDale ClydeSDale is offline
ClydeSDale is gaining momentum as a positive member of FTE.
Great stuff tgore3 .... thanks for posting it!
Old 09-22-2006, 07:16 PM
No problem
Old 04-18-2011, 07:17 PM
DHCowdude's Avatar
DHCowdude DHCowdude is offline
DHCowdude is starting off with a positive reputation.
Great chart - answered my next question without having to post a new thread. Thanks!!
Old 09-22-2013, 01:12 AM
JackErnie JackErnie is offline
JackErnie is starting off with a positive reputation.
Thanks for all the info, folks. I'm new here - I'm working on restoring an '81 F150 short box, stepside, 4x4; restoring an '86 F350 crew can, longbox dually; an '86 F250 4x4 on propane; and a '91 F250 7.3 IDI 4x4. You folks always have the answers to my questions, even before I post them!
Old 09-22-2013, 01:38 AM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
E A 2B0550 9 S319B
S319B = Ford 9" WFE rear axle / 3.50-1 / Limited Slip / 3,750 lbs. rear axle capacity.
Old 09-22-2013, 01:48 AM
I attempted to read the tag on mine in darkness, using flashlight. It's weathered a bit since '81. I'll clean the tag off in AM and give it a better look.
350 ratio, 4 speed tranny, 351 engine, and a light weight truck should give me fairly respectable gas mileage.
My '81 F150 stepside shortbox is my baby that will only be allowed outside when the weather is nice and the roads are dry. Same goes for my '86 F350 crewcab dually - I have younger trucks to do the serious work. My Old Dually is only allowed out to play when the road is good.
Fords Forever!
Old 09-22-2013, 01:58 AM
Fords Forever!
Welcome to FTE
Ford = Flareside, a stepside is a (gasp) Chevrolet.
Old 09-22-2013, 02:04 AM
Ouch! Flareside/stepside...thanks, I'll try to get it right from here onwards!
Thanks for the welcome.
rear axle swaps greentruck72 1973 - 1979 F-100 & Larger F-Series Trucks 6 05-20-2015 03:13 PM
Simple, Stupid axle question redman84 1994.5 - 1997 7.3L Power Stroke Diesel 22 08-05-2012 11:18 AM
31 spline axle's? 73-79 F100-F150s 1967 Turbo 6.9 1973 - 1979 F-100 & Larger F-Series Trucks 11 11-29-2008 07:04 PM
axle codes..... BroncoRoadKill 1978 - 1996 Big Bronco 18 02-16-2006 06:44 PM
C9 axle code 77bigblock 1987 - 1996 F150 & Larger F-Series Trucks 4 12-20-2005 05:37 PM
Tags
axle, codes, dana, ratio
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
