Neutral safety switch wiring location on 78? - Ford Truck Enthusiasts Forums
Old 09-09-2006, 05:23 PM
dichdoc dichdoc is offline
dichdoc is starting off with a positive reputation.
78 bronco with 351 and auto trans the nuetral safety switch on the drivers side of the tranny has never been hooked up since I bought the truck. I'm trying to wire in an auxilary back up light and figured out my factory lights don't work. Question is where does the four prong connector from the switch go to? The wiring diagram is of no help. I can't seem to find a matching connector anywhere on the truck. Please help. Travis
Old 09-09-2006, 11:22 PM
greystreak92's Avatar
greystreak92 greystreak92 is offline
greystreak92 has a great reputation on FTE.greystreak92 has a great reputation on FTE.greystreak92 has a great reputation on FTE.greystreak92 has a great reputation on FTE.greystreak92 has a great reputation on FTE.
Thats because two of the wires are fed by separate power sources. The RED/LT. BLUE one from the start relay, and the PURPLE/ORANGE one that is fed by the directional/backup light fuse in the fuseblock. The RED/LT. BLUE continues on to the ignition switch and the BLACK/PINK continues on to the back up lights. So you won't find those four wires together anywhere else in the truck.
Just a note: The wire colors I have listed here are for a 1980 model so the wire colors in your 78 may be different.
Old 09-10-2006, 11:51 AM
dwoodler's Avatar
dwoodler dwoodler is offline
dwoodler is starting off with a positive reputation.
Is the tranny original? IS the nuetral safety original? That could be why there is no matching connector. I haven't looked at the one on my 79 in a while so I can't tell you what it looks like or where the wires go - it's raining right now so once it dries out I'll give it a boo and let you know what I find.
In my Haynes it says - Disconnect the two multiple wire connectors.
Do you have two two wire connectors nearby?
Old 09-10-2006, 09:28 PM
I'm not sure if either are original I have a receipt for a tranny rebuild from the previous owner but no real idea. The four wires come off the switch and go into one four female factory type connector. For my purpose of back up lights could I just power the red black from a power source?
Old 09-11-2006, 09:31 PM
husker's Avatar
husker husker is online now
husker has much to be proud ofhusker has much to be proud ofhusker has much to be proud ofhusker has much to be proud ofhusker has much to be proud ofhusker has much to be proud ofhusker has much to be proud ofhusker has much to be proud ofhusker has much to be proud ofhusker has much to be proud of
On the 4 prong, I would guess that one wire is from the start switch going to the neutral safety switch and the other is the return that goes to the starter solenoid. My neutral switch was bad on my 78, so I bypassed it at the 4 prong connector above the rear of the engine along the firewall. I can't check right now, but if you need to know which are the ignition wires, I can check tomorrow when there is some light.
Automatic trans harness in a manual trans truck? straight-shot 1967 - 1972 F-100 & Larger F-Series Trucks 3 01-13-2016 05:19 PM
Need assistance with dash lighting and turn signal problems Canus 1973 - 1979 F-100 & Larger F-Series Trucks 14 09-08-2014 04:10 PM
Wiring ID at Connector to Neutral Safety Switch 80s Trucker Electrical Systems/Wiring 3 08-21-2014 07:29 AM
Neutral safety switch HELP!!! shruck 1973 - 1979 F-100 & Larger F-Series Trucks 19 03-04-2013 10:24 PM
Neutral Safety Switch - reverse light problem Dskeet6 1973 - 1979 F-100 & Larger F-Series Trucks 4 09-14-2010 10:29 PM
Tags
1978, 4x4, bronco, diagram, f100, f150, ford, neutral, nuetral, nutril, safety, safity, saftey, safty, switch, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
