VIN number?
VIN number?
I recently bought a 61 SWB stepside with good title, however I was not sure the vin matched the title since the driver door had been changed. I found the frame stamp by the front axle and it had a letter and the last 6 digits of the vin on the title. Is that all they stamp or do they usually have the first part as well- for example f10J was missing and D -with the other 6 digits were on the frame? Also were can you get the information to decode your vin #? Thanks in advance
Kevin
Kevin
VIN number?
Kevin, It all should be there, sometimes it's just hard to see. Try Jon's site, it should have what you need. It is also linked through my FTE site.
John
jowilker
[link:www.ford-trucks.net/users/jowilker|Club FTE since 01 01] My FTE Page
[link:www.ford-trucks.net/users/jowilker/NCFTE.html|NC Truck Owners] NC Ford Truck owners group
66F100s Rule
In the cool still quiet of night you can hear chevies rusting away.
John
jowilker
66F100s Rule
VIN number?
I had the same problem with my 64 F100, in order to legaly impor it into Mexico I needed the frame VIN. Besides the one in the frame close to the front axle, there is a second VIN on the same frame but its under the cab, some times the numbers are hard to read but it should start like *F10.
Get your self a wire brush to clean it up, If you go with a sand paper you may loss what you already have.
Good luck and keep us updated.
old broke prospector
22
03-11-2013 06:14 PM
AXracer
09-22-2012 07:49 AM
Robb J
09-22-2010 12:09 PM
