cruise control not working - Ford Truck Enthusiasts Forums
1968-2013 Full Size Vans Econolines. E150, E250, E350, E450 and E550
Old 09-09-2006, 06:19 AM
mikes econoline mikes econoline is offline
mikes econoline is starting off with a positive reputation.
Unhappy cruise control not working
wondering if anybody had suggestions i have a 03 E-250 and the cruise control stoped working the fuse is still good and dont know my next step to fix this problem any suggestions would be helpful
thanx
Old 09-09-2006, 10:03 AM
pfogle's Avatar
pfogle pfogle is offline
pfogle has a good reputation on FTE.pfogle has a good reputation on FTE.pfogle has a good reputation on FTE.
Do you have an air bag light flashing? Does the horn still work? If the answers are yes and no, you have a bad clockspring. Does the speedo work correctly? The cruise control is controlled by a speed sensor in the top of the differential, so it's possible that you've got a loose wire somewhere preventing it from working. If it's an aftermarket system then you'll need to crawl under the van and solder all the connections where there are butt connectors. This is a common mistake made by dealerships that install the aftermarket systems to please their customers. Water gets into the connectors and corrodes the wires and connector resulting in loss of contact.
Old 09-09-2006, 01:56 PM
hatch_1989 hatch_1989 is offline
hatch_1989 is starting off with a positive reputation.
When my crusie went out in my 1992 E150 it turned out to be the buttons in the steering wheel had worn out. To replace you disconnect the battery and let it sit for a while to de-energize the air bag. I let mine sit overnight. Remove the air bag and the buttons are right below. Prior to remaoval, there is a diagnostic procedure to figure out whether the buttons are bad. You can find it in the factory manual. In order to run through the procedure you have to disconnect a harness thats below the master cylinder and jump pins in the connector checking for continuity and/or voltage between various pins. I broke the plastic connector lock on mine, now the connector is held together with a plastic quick tie.
Old 09-09-2006, 04:36 PM
everything is workin fine and its a factory cruise control the wire on the diff is that aftermarket only? As for the buttons being bad did your still light up when they were bad mine still light up at night
thanx
Old 09-09-2006, 04:41 PM
Clubwagon Clubwagon is offline
Clubwagon is starting off with a positive reputation.
The "wire on the diff" is the factory installed speed sensor. If it wasn't working it would set a speed sensor code and flash the OD light.
My bet is the clock spring.
Steve
'95 Clubwagon XLT
Old 09-10-2006, 06:07 AM
pfogle's Avatar
If it's a loose wire it may or may not set a code. You can pull the codes yourself to check. If the horn works, and no air bag light then the clockspring is still fine.
Old 09-10-2006, 06:56 PM
al_e._gator's Avatar
al_e._gator al_e._gator is offline
al_e._gator is starting off with a positive reputation.
Check the brake position switch. If the contacts are stuck closed it will keep the system from working. There is also a normally closed brake pressure switch on the front of your master cylinder that is supposed to open and deactivate the system under heavy braking if the brake position sensor fails.
Old 09-11-2006, 07:03 PM
Most of the time a cruise control stops working because the buttons wear out. The more often you use your cruise control, the more likely the buttons willl be shot. There is a 10 step procedure you run through, we got up to 9 or 10 before we caught the failure.
If you dont have the procedure I will see if I can find it for you.
Old 09-12-2006, 05:39 AM
I dont have that procedure if you could find that it would be great
THANK YOU
Old 09-12-2006, 07:01 PM
Done_Deal Done_Deal is offline
Done_Deal is starting off with a positive reputation.
Cruise Control buttons
My 03 E250 cruise control works intermittently.
I have gotten it to work by stabbing the buttons hard so I think my problem is with the buttons on the steering wheel.
Old 09-12-2006, 07:32 PM
I will post the procedure once I have found my CD with the manual on it.
Old 09-14-2006, 09:59 AM
Control Button Diagnosis
One other thing to check is where the cruise cable attaches with the throttle cable on top of the engine. The connector on mine broke so I latched it down with a quick-tie rather than replace the whole cable. That was 30,000 miles ago.
Here is the diagosis procedure as promised.
A1 VISUAL CHECK
Perform visual check.
GO to A2.
A2 SETUP
Disconnect harness connector from the servo assembly.
Use Rotunda Digital Volt Ohmmeter 014-00407, or equivalent, to make the specified measurements at the harness connector.
GO to A3.
A3 VERIFY THERE IS POWER TO SERVO
With the ignition switch in RUN, measure voltage between Pin 7 (B+, Circuit 296) and Pin 10 (GND, Circuit 131).
Battery voltage (12v nom.)
Module has power, GO to A4.
Open circuit (0 volts)
No power, GO to B1 .
A4 CHECK FOR STUCK BRAKE SWITCH
With no brakes applied, measure the voltage between Pin 4 (BRK, Circuit 511) and Pin 10 (GND, Circuit 131).
Switch is not stuck on, GO to A5.
Switch is stuck on, REPLACE brake switch.
A5 CHECK BRAKE/CLUTCH CIRCUIT
With the ignition switch in OFF position, measure the resistance between Pin 4 (BRK, Circuit 511) and Pin 10 (GND, Circuit 131).
<20 ohms
Brake input Circuit OK, GO to A6.
>20 ohms
Brake light bulbs blown or brake circuit open, SERVICE circuit including clutch switch.
SPEED CONTROL INOPERATIVE -- TEST A
A6 CHECK DEACTIVATOR SWITCH CIRCUIT
With ignition in OFF position, and with no brakes applied, place a 12 Volt Circuit Test Light between Pin 9 and Pin 10 of the Servo Harness Connector.
Is the light Illuminated?
Yes
GO to A7.
No
No power from Deactivator, GO to C1 .
A7 CHECK FOR STUCK ON SWITCH
With no steering wheel switches depressed, measure the voltage between Pin 5 (COMMAND, Circuit 151) and Pin 10 (GND, Circuit 131).
"ON" switch not stuck, GO to A8.
REPLACE switch.
A8 CHECK ON SWITCH OPERATION
With ignition switch in OFF position with steering wheel ON switch depressed, measure voltage between Pin 5 (COMMAND, Circuit 151) and Pin 10 (GND, Circuit 131).
ON switch OK, GO to A9.
"ON" switch not functioning GO to D1 .
A9 CHECK FOR STUCK COMMAND SWITCHES
With ignition switch in OFF position and with no steering wheel switches depressed, measure the resistance between Pin 5 (COMMAND, Circuit 151) and Pin 6 (COMMAND RTN, Circuit 133).
>3k ohms
No stuck switches, GO to A10.
<3k ohms
One of the command switches is stuck, REPLACE switch.
A10 CHECK SET/ACCEL SWITCH OPERATION
With ignition switch in OFF position and with the SET/ACCEL switch depressed, measure the resistance between Pin 5 (COMMAND, Circuit 151) and Pin 6 (COMMAND RTN, Circuit 133).
Approx 680 ohms
Switch is OK, GO to A11.
<640 or >720 ohms
Switch not functioning, REPLACE switch.
A11 VERIFY SPEED SIGNAL
Operate vehicle by raising the rear wheels. Set speed at 30 MPH. Use an AC voltmeter to measure the voltage between Pin 3 (SPEED SIG, Circuit 130) and Pin 10 (GND, Circuit 131).
4-5 volts
Speed signal OK, GO to A12.
No reading
SERVICE Programmable Speedometer/Odometer, GO to Section 13-02A, Speedometer/Odometer.
A12 CHECK FOR BROKEN OR BOUND ACTUATOR CABLE
Remove actuator cable from servo assembly, check for broken cable by pulling on cable and noting throttle movement.
Cable is OK
REPLACE servo assembly.
Binding or broken cable
SERVICE cable.
Old 09-20-2006, 09:46 AM
I was wondering whether you ever got your cruise control working.
Old 09-20-2006, 08:02 PM
To tell you the truth i havent got into it yet i have 2 kids under the age of 3 time is limited but the cruise is on my list im heading up to the fall carlisle show and would love to have it working by then thanks for showing interest.
Old 09-20-2006, 08:24 PM
MikeB 88's Avatar
MikeB 88 MikeB 88 is offline
MikeB 88 is gaining momentum as a positive member of FTE.
When the cruise quit working on my '88 F-150, I did all the troubleshootong in the manual. It wound up that the cable to the throttle came unhooked. Hooked it back up, and it's been working since.
Mike B
2002 Ford Expedition Cruise Control Not Working hawesra 1997-2006 Expedition & Navigator 2 07-21-2014 08:01 PM
I'm Puzzled???? PLEASE help! LoyBaird 1997 - 2003 F150 2 04-06-2014 09:35 PM
cruise control light octaneforce 1987 - 1996 F150 & Larger F-Series Trucks 2 11-19-2009 07:57 PM
2006 F150 Cruise Control Problem Engineer2 2004 - 2008 F150 3 12-30-2008 05:54 PM
1994 F-150 cruise control Domino Electrical Systems/Wiring 4 02-11-2003 11:21 PM
Tags
07, 2003, 2004, 2005, aftermarket, broken, buttons, control, cruise, diagnois, e350, econoline, f350, ford, photos, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
