First order a new cps off e-bay ($50-75) or go to you local international dealer ($90-100). It is simple but it is tight under there. You need a 10mm ratchet, under the truck find the crankshaft and pully, @ the 10 o clock position there it is. You might have to pry the old one out just take your time.
