Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #16 (permalink)
Old 09-21-2006, 01:18 PM
Redmanbob's Avatar
Redmanbob Redmanbob is online now
FE Pwrd F100 RaciN-waNabe
1964 Ford F-100
My Garage
Redmanbob is gaining momentum as a positive member of FTE. Redmanbob is gaining momentum as a positive member of FTE.
If your going to use hardened seats whats wrong with those heads ? NAPA, pick apart, you name it..Personally I'd look for a whole engine as donor considering the issues so far.
__________________
66 F100 352FE / Cruiso
64 F100 352FE / T-98
"Po-Dunk Redkneck Transplant"
CRATE = Cant Really Appreciate The Engine..
http://www.ford-trucks.com/forums/61...vs-west-3.html
http://www.youtube.com/watch?v=1nX38wamqwY
  #17 (permalink)
Old 09-24-2006, 07:51 PM
LedheadELH LedheadELH is offline
LedheadELH is starting off with a positive reputation.
well hardened seats won't make that much of a differece. it just makes it so you don't have to do a valve job ever few thousand miles because of your seats being beat to death w/ unleaded feul, but if U have a knock and only at load usually that means Main bearings. take the spark plug wire off the suspected cylinders to ground them out, and tell me if the knock gets lounder, quieter, or stays the same. if it stays the same, it's probly the mains.
__________________
'86 F-250 460,T19, D44/10.24
'78 Bronco chassis w/ 62' F-100 body 360, NP435,205, D60/D60
Early '77 F-250 400, 435, Divorced205
  #18 (permalink)
Old 10-11-2006, 09:24 AM
dlowenst dlowenst is offline
dlowenst is starting off with a positive reputation.
Just to close the loop on this thread:
After removing the heads and doing a thorough examination with measurements, the main problem turned out to be (as predicted by several posters here) a cooked head gasket in between cylinders #3 & 4. The mechanic did find a vacuum leak that he believed was at least part of the cause. In addition, the heads had previously been improperly rebuilt without replacing valve guides.
Both heads have now been rebuilt with new valves, guides, seals, seats and head bolts, and bolt holes fully chased and cleaned. It's now running great, with much more power.
Thanks again for all the guidance.
Dave
  #19 (permalink)
Old 10-11-2006, 11:14 AM
Krewat's Avatar
Krewat Krewat is online now
Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future
Dave, thanks for posting that follow up!
I'm glad it turned out to be relatively(!) simple.
Good luck with it!
__________________
- art k. - Moderator for the Superduty, V10, and FE forums
'01 F250SD SC SB XLT V10 4x4 auto 3.73 Warn hubs Volant CAI, eBay headers and y-pipe - 5-star custom tunes on SCT X3
'97 Cougar XR7 30th Anniv Edition 4.6L
'74 F250 Highboy FE390 deceased!
I've been wrong before, I'll be wrong again. Just wait and see.
Tags
390 , 460 , acceleration , car , distributor , engine , fix , ford , knock , knocking , knocks , load , motor , rod , running
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
