Edge tuner or ?????
Edge tuner or ?????
I have an Edge tuner and it is ok but I would like to know if there is a better tuner out there or is it waste of money for the difference ( if any ) over another brand ?? Mine is a few years old and I did not know if I could get an few more horses out it??? It is only the three setting and no flip switch.
96' F-250 PSD 7.3 185,000 mi
I ran the evolution for about 1 year before I switched over to a dp tuner 4 position chip. The thing that really sets our trucks back is their injector size (100cc). They limit how much fuel the motor can intake. I read that a well tuned engine can make between 2-2.2 hp for every cc in injector size, so with stock injector you will not make more than 220HP. I did notice a big difference in how smooth the engine runs with the dp tuner chip.
With the edge I could get a peak boost of 24psi and A LOT of smoke
With the dp tuner I can get 26 psi with less smoke than the edge.
Also egts are cooler when towing. I really like to be able to switch setting on the fly. But if are looking for more HP your stock injectors are maxed out with the edge.
yahnke
Conventional (Bumper Pull) Towing; Travel Trailers & Pop-ups
07-01-2016 01:54 PM
Damien05
03-07-2016 05:06 PM
