Winnebago engine size??? - Ford Truck Enthusiasts Forums
Old 09-07-2006, 12:10 PM
sirfranky sirfranky is offline
sirfranky is starting off with a positive reputation.
Smile Winnebago engine size???
Does anyone out there have any info on the size of engine in an 86 winnebago 31 footer it looks to be a 460 with a c-6 trans.
Old 09-07-2006, 01:44 PM
monsterbaby's Avatar
monsterbaby monsterbaby is offline
monsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputation
If it's a Ford Chassis then yes it's probably a 460, Winnebago used ford and chev chassis (plus some others too I beleive) I don't beleive you could get that big of one with anything but a big block.
Old 09-07-2006, 06:33 PM
Okay if you believe it is a 460 how similar is it to a 460 out of a 79 F 150.
Old 09-07-2006, 06:48 PM
460mudtruck 460mudtruck is offline
460mudtruck is starting off with a positive reputation.
i have a 86 tioga arrow and it is a 460 what would that mean
Old 09-08-2006, 01:31 AM
Quote:
for all intents and purposes it should be the same engine (provided that the one in the 79 F150 is actually a 79 motor of coarse and not an earlier model transplanted)
Old 09-08-2006, 10:46 AM
The reason I am asking this is I have a 460 out of my 79 it is actually has heads from an 82 or so from a previous rebuild, the block was in excellent shape with 0.30 pistons I had the the distributor recurved and the crank turned. They also put in new cam bearings and freeze plugs for me. I have not bought the other parts for the rebuild yet I kinda lost interest at the moment. So I was pondering at saving it for if the Winnebago ever broke down. I also have this c-6 trans is it worth saving for the winnebago? Or is it different internally. Thanks for your imput.
Old 09-08-2006, 01:23 PM
internally the C6 should be the same (the winnibego might have the heavier clutch packs in it but might not too) the engines should be the same, expecially if the casting number on the side of the spare block is D9TE, should be right above the starter, and that will be the same casting number on the block in the motorhome. the heads on the 79 should be D3VE and the heads on the motorhome engine might be E5 or something like that but they are totally interchangable.
New Ford Chassis Owner JimGeorgia New Member Introductions 0 10-25-2014 07:29 AM
macrox macrox New Member Introductions 3 06-30-2014 09:58 PM
change o pace change o pace New Member Introductions 4 08-20-2013 11:56 AM
1997 Winnebago with 460....idles rough after traveling 400 miles shajoe44 Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 20 02-24-2010 09:16 AM
1970 winnebago restoration tg 1967 - 1972 F-100 & Larger F-Series Trucks 1 07-24-2000 07:12 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
