rear end axle code.....h9 - Ford Truck Enthusiasts Forums
Old 09-07-2006, 12:31 PM
z 97ford1 z 97ford1 is offline
z 97ford1 is starting off with a positive reputation.
Someone removed my rearend i.d. tag from the rear so I'm trying to find out what "ratio" my rear is.
The code on the door panel shows "H9" meaning limited slip but where can I get the gear ratio?
I think it is 3.55 but I don't know.
does anyone have a clue?
97 f150 4x4 4.6 v8 auto
Old 09-07-2006, 12:37 PM
ATC Crazy's Avatar
ATC Crazy ATC Crazy is offline
ATC Crazy has a very good reputation on FTE.ATC Crazy has a very good reputation on FTE.ATC Crazy has a very good reputation on FTE.ATC Crazy has a very good reputation on FTE.
H9 = 3.55 LS
Check the tag on the rear axle though. There have been several reports of non-matching numbers between the door sticker and the rear axle tag.
The tag will be on held on by one of the differential cover bolts. If it's rusted, take a wire wheel/brush to it.
It should start out like "3L55" if it's a 3.55 LS
Old 09-07-2006, 12:44 PM
Ford Fx4's Avatar
Ford Fx4 Ford Fx4 is offline
Ford Fx4 has a good reputation on FTE.Ford Fx4 has a good reputation on FTE.
yep, h9 3.55ls
Old 09-07-2006, 08:46 PM
kspilkinton's Avatar
kspilkinton kspilkinton is offline
kspilkinton has a very good reputation on FTE.kspilkinton has a very good reputation on FTE.kspilkinton has a very good reputation on FTE.kspilkinton has a very good reputation on FTE.
Since we are on the subject of missing tags, and you want to know your ratio... but are not too keen on believing the door jamb sticker -
Jack the truck up and do the turns test - 1 complete turn of the driveshaft should equal a slight bit more than 3 1/2 turns of the tire, if you have the 3.55 ratio. Or was that the other way around????
-Kerry
Old 09-07-2006, 11:04 PM
ATC Crazy's Avatar
Quote:
-Kerry
You got that backwards. One complete turn of the tires would equal 3.55 turns of the driveshaft.
Old 09-08-2006, 12:38 AM
Actually, I called ford parts and gave them my vin.....last 6 digits and they was able to id it as 3.55-but thanks for the info.
Old 09-08-2006, 05:14 PM
LxMan1's Avatar
LxMan1 LxMan1 is offline
LxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant future
That's a pretty common gear in the 4x4's. Someday I will have 4.10's in mine, just can't afford to do two axles
finding gear ratio for mystery Ford 9 Mr7.50headsup Clutch, Transmission, Differential, Axle & Transfer Case 2 02-21-2014 05:10 PM
2010 F150 front and rear axle driptorch970 2009 - 2014 F150 1 12-16-2010 05:00 PM
Rear Axle Ratio thiggy 1997 - 2003 F150 4 10-14-2010 04:04 PM
Axle code jonrer Clutch, Transmission, Differential, Axle & Transfer Case 1 11-25-2003 08:26 PM
H22 Axle code Fordman7780 Clutch, Transmission, Differential, Axle & Transfer Case 2 11-03-2002 07:01 PM
Tags
150, 1997, 2001, 2004, 2009, axel, axle, bronco, code, door, f150, ford, h9, jam, ratio
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
