5.4L problems. - Ford Truck Enthusiasts Forums
5.4L problems.
Old 09-07-2006, 01:57 AM
Lunchbox1980 Lunchbox1980 is offline
Lunchbox1980 is starting off with a positive reputation.
5.4L problems.
I'm driving a 2000 F-250(4x4/4.10 gears) with a 5.4L and recently I've had some engine problems. Nothing major I don't think/hope.
When I go to accelerate the engine "chugs"(stutters, boggs down, feels like its being choked)... holding a steady speed almost always eliminates the engine stutter... at first I thought it was the coil packs but after talking with some friends and them test driving it they are convinced its a fuel problem. Since it was time for new plugs anyway I put new plugs in and it looks like the engine is running very lean.
The fuel filter is new(less than a week) so my friends and I are thinking its either one of the O2 sensors or the MAF... I have a full custom dual exhaust with no X,H,Y pipes... no cats... and my O2 sensors look pretty rough(too many trips to the woods/mud holes I guess)
I was hoping to get any ideas, maybe someone has had this problem before that could point me in the right direction.
Old 09-07-2006, 05:45 AM
IB Tim's Avatar
IB Tim IB Tim is online now
Site Administrator
IB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputation
...Welcome to Ford Truck Enthusiasts!
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
..See you on the boards.
Old 09-07-2006, 05:01 PM
sednec sednec is offline
sednec is starting off with a positive reputation.
How many miles do you have on your truck? I had similar problem cleaned maf and changed egr valve position sensor, drives much better
Old 09-07-2006, 05:56 PM
ReAX's Avatar
ReAX ReAX is offline
ReAX is a splendid one to beholdReAX is a splendid one to beholdReAX is a splendid one to beholdReAX is a splendid one to beholdReAX is a splendid one to beholdReAX is a splendid one to behold
Did it start when you had the exhaust installed? If you haven't changed o2 sensors in the last 15-30K miles, you might as well take this opertunity to do so. A ballance pipe will help bottom end torque. Clean the MAF, pull the throttle body and IAC, give them a good cleaning.
Does the exhaust smell under load/accelleration (or reving while parked?)
Old 09-08-2006, 01:00 AM
My truck has about 130K. After checking around its just the drivers side bank thats running lean. I ordered an O2 sensor from summit should be here in the morning. Once I wrench that off and replace it I'll clean the MAF and see how she runs then.
Yes the exhaust smells a bit under load/accelleration.
Also on the chance that a coil has gone bad I ordered 8 Accel Super coils, only because I could talk them down to $15 a coil because of a misprint on thier webpage
The problem didn't start because of the exhaust because it ran fine when I bought it and the exhaust was already on it. I'm still looking around for a Ballance Pipe... I'd need an X-pipe but because of the tansfer case the 2 exhaust pipes are run so close together I need a very tight/narrow/close X pipe and I just haven't found one yet(haven't looked real hard though)
Old 09-08-2006, 01:50 AM
Also while I'm bugging you guys with questions... Can anyone reccomend a cold air intake kit that won't turn into a straw and suck water into the engine the first time I hit some deep water?
Old 09-08-2006, 04:04 PM
LxMan1's Avatar
LxMan1 LxMan1 is offline
LxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant future
Old 09-08-2006, 04:52 PM
ReAX's Avatar
The k&n kit rides fairly high, see my gallery.
2003 Aviator - slight stutter in auto shifting ReluctantMechanic Explorer, Sport Trac, Mountaineer & Aviator 2 08-29-2014 04:03 PM
Engine oil in my air intake idontknowcars 1997 - 2003 F150 2 02-14-2014 09:45 PM
Same Ol 5.4 Stutter amusick10 Modular V8 (4.6L, 5.4L) 6 08-27-2013 09:06 AM
Intermittent Engine Stutter savage250 1994.5 - 1997 7.3L Power Stroke Diesel 23 09-14-2010 10:58 AM
pinging and missing garbear17 1997 - 2003 F150 6 01-09-2010 01:09 PM
Tags
350, 54, 54l, engine, factory, failure, ford, liter, litre, motor, problems, recall, rocker, troubles, v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
