Bench seat foam
I bought a whole set kit from Mid-fifty. I went for the thicker foam which they said wasn't that great for big people. I'm 6'7" and have no problem with it. The seat cover fits great and the foam is firm and supportive. The only problem I had was getting the back support back on without tearing the seat bottom cover because it was so tight. The upholstery place I used made some plastic washer shaped things that fit between the metal support of the back rest and the side of the seat bottom cover and keeps it from rubbing and tearing the fabric. They fit over the pin that holds the back onto the seat bottom frame.
I heard about somewhere online selling that memory foam stuff; you know, what the high-dollar mattresses are made of? They sell it in blocks for you to do whatever with. You supposedly can cut it to fit just about anything, but for the life of me, I can't remember where I heard that...not even sure that stuff would make a good seat cushion anyway...may have permanent butt prints in the seat...
My foam is 3 different densities and the leather and the inserts were ( are ) real tight, but I used waxed paper between to act as a slip. The paper can be left in but you will hear it ( temp ) if you are using fabric. It can be taken out if you put it in long ways so you can reach it from the back and bottom prior to hog ring/sewing. It just an old production trick from the suppliers to Detroit. Some guys also reverse the cover and install over the foam like a pillowcase. If you are using vinyl, then just heat with a blow dryer prior to install.
Sure did. MidFifty can ship it less expensively than he can cut it. Only question was if the foam was high-quality and firm enough. The local fella is going to make the cover for me because I didn't like any of what the catalogs had to show.
I'm in good hands, he's rebuilt a couple of 56's of his own
I've been considering a re-working of my seat back to make it thinner. In the search for foam I ran across this place: http://yourautotrim-store.stores.yah...oamsheets.html Their prices seem pretty fair, for all that I can tell (I haven't looked at the mid-fifty foam). Anyway, it's another option for foam and materials.
Originally Posted by ALBUQ F-1
...aircraft seat foam comes in all the same densities and such as automotive, but is fire-rated. It won't torch off as fast and doesn't produce near the toxic fumes if it does burn.
rbond
23
11-09-2016 08:06 PM
Turbo Dog
18
11-20-2015 11:17 PM
SideWinder4.9l
11-17-2010 12:48 PM
