Quote:
Originally Posted by amdc5c5
Hi new here to the forum.
If anyone can help find out how I can know what rear end a Ford F350 dually has by the vin #??
Also, how many miles can a 2004 6.0 engine have if mainly highway driving? With proper care ofcourse>...
400K??or ++
Go to the link below and scroll down until you see the door jamb sticker and the various codes...
http://dan.prxy.org/Truck/Super_Duty...des_FRAME.html
Look for "axle" and the 2 digit number... here is the list of codes as one will be on the door jamb sticker...
The following lists the gear ratios on rear axles.
31 3.73 non-limited slip, F-250/Excursion
32 4.10 non-limited slip, F-250
41 3.73 non-limited slip, F-350
61 3.73 non-limited slip, F-350
73 4.30 non-limited slip, F-450
75 5.38 non-limited slip, F-450
78 4.88 non-limited slip, F-450
81 3.73 non-limited slip, F-350
88 4.88 non-limited slip, F-350
95 5.38 non-limited slip, F-550
98 4.88 non-limited slip, F-550
C1 3.73 limited slip, F-250/Excursion
C2 4.10 limited slip, F-250/Excursion
C3 4.30 limited slip, F-250/Excursion
D1 3.73 limited slip, F-350
D2 4.10 limited slip, F-350
D3 4.30 limited slip, F-350
E2 4.10 limited slip, F-350
E3 4.30 limited slip, F-350
EW 4.10 limited slip, F-350 (ambulance package)
F1 3.73 limited slip, F-350
F2 4.10 limited slip, F-350
F6 4.56 limited slip, F-350
G3 4.30 limited slip, F-450
G5 5.38 limited slip, F-450
G8 4.88 limited slip, F-450
GW 4.88 non-limited slip, F-450 (wide frame)
K5 5.38 limited slip, F-550
K8 4.88 limited slip, F-550
KW 4.88 non-limited slip, F-550 (wide frame)
