Error Codes on Dash Display - Ford Truck Enthusiasts Forums
Old 09-05-2006, 11:31 PM
hmolivas hmolivas is offline
hmolivas is starting off with a positive reputation.
Question Error Codes on Dash Display
Hi Everyone !!!
Im the new guy and had some questions.
I have an 04 F-150 super crew lariat. (this would make it my 3rd FORD )
I recently have seen 2 errors on my dash display. They are as follows :
1.Autolamp delay data error
2.Auto lock data error
Can anyone help me with this ? I just bought the truck (used) therefore its out of warranty.
Also the radio stays on when I shut off the truck and pull the key out. its stays on for a while (5 mins or so) and then shuts off. Is this normal ? can it be disabled?
ANY HELP WOULD BE GREATLY APPECIATED .
Old 09-06-2006, 12:21 AM
1979FordF-250's Avatar
1979FordF-250 1979FordF-250 is offline
1979FordF-250 is starting off with a positive reputation.
Exclamation
I can tell you that there is something wrong with your radio. It should shut off at the off position where you can remove the keys. It should never play for 5min after you take the keys out.
Old 09-06-2006, 12:27 AM
cool guy cool guy is offline
cool guy is starting off with a positive reputation.
there's nothing wrong with your radio, open up the door and it will turn off......it's normal, i got the same setup .... it has the delay timer...
Old 09-06-2006, 12:30 AM
for your error codes check your manual how to reset it or just disable it through your mini message center....and see if you can turn it on again....
Old 09-06-2006, 06:37 AM
IB Tim's Avatar
IB Tim IB Tim is online now
Site Administrator
IB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputation
...Welcome Olivas, to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
..See you on the boards.
Old 09-06-2006, 07:21 PM
Thanks for the info guys !!
Coolguy- I do open the door. I open it get out of the truck lock the truck and the radio is still playing (wierd huh??)
as fas as the codes go. The message center will not let me reset them.
would this utimately turn out to be a dealer issue?
Old 09-07-2006, 07:29 AM
that is wierd! well i guest your right about the dealership fix....see if someone else could help you through this issue in here....
Old 09-07-2006, 07:45 AM
96f150's Avatar
96f150 96f150 is offline
96f150 is starting off with a positive reputation.
Just for kicks, do your power windows still work with the key in off position? If so, your RAP (retained accessory power) module may be bad. Just a thought
Old 09-07-2006, 07:10 PM
yes they do
That make sense and sounds like a source to look at. do you know where FORD put this module?
I looked at Mitchell and it was kind of vague on where this module is
Old 10-22-2013, 05:23 PM
pearlofagirl100 pearlofagirl100 is offline
pearlofagirl100 is starting off with a positive reputation.
I have the exact same problem. hmolivas, did you ever get it fixed? What did you have to do exactly?
2006 indash factory 6 disc player trmann 1999 to 2016 Super Duty 6 08-07-2012 12:40 PM
2005 Explorer CDs wont eject StephanieStroh Explorer, Sport Trac, Mountaineer & Aviator 1 09-20-2011 10:48 PM
How to Tell if in REGEN tylem28 6.4L Power Stroke Diesel 11 11-22-2010 10:43 PM
code reader error raptor2005 6.0L Power Stroke Diesel 3 02-15-2010 04:03 PM
CD Changer Error planet89 2004 - 2008 F150 4 02-27-2009 04:03 PM
Tags
2004, 42, auto, code, codes, dash, data, display, engine, error, f150, ford, lock, locks, read, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
