New to 5.4 - Several Questions
As everyone can probably tell, I migrated from the 6.0 Diesel section. A few weeks ago I bought myself a 2008 F250 with a 5.4. I do have several questions:
It is a 2008 with 116,000 miles on the odometer
The guy I bought it from had replaced the engine in it. The tag on the engine indicates a build date of 4-21-06. It supposedly had 40,000 miles on it. He told me that the mechanic that installed it replaced the spark plugs and replaced one of the timing chain guides.
What model year would the engine be considered for replacement parts and trouble shooting?
I do hear, what I would describe from the old days as lifter noise. It is not a ticking, but more of a swooshing, RPM specific, that is slightly louder when the engine is cold vs. warm. RPM at idle is perfect at 640, fluctuating only about 5-10. It idles very smooth, hardly detectable.
I do not know what kind of oil was used in the truck, but the filter was after market. I changed it to 5W20 with a **** filter the day after I bought it.
The rear end is geared 3.73, and coming from a chipped diesel, this one seems sluggish. I realize this is a very heavy truck for the engine, but should it feel heavy. The "lie o meter" tells me my MPG is 9.4 driving in the city. Have not yet had a good chance to take it on the highway.
So, to summarize in trying to learn the 5.4.
What would the model year be considered
What should I check with the swooshing/lifter noise
Thank you in advance from reading this long one.
Well had some time to check into stuff with my trusted stethoscope. Did not hear anything what I would consider out of the ordinary on the valvecovers. I was not really look for exhaust manifold leaks. I did place the probe on top of each coil pack and heard ticking on all of them with the exception of the passenger side very back one, more on that one later, and the second from the front. Again the truck idles very smooth. On the very back coil pack mounting bolt the plastic had broken so it is loose. I pulled it out and there was no evidence of burning or leakage on the boot. So I put it back in. I will replace it this weekend.
Now, should I hear a ticking on every coil pack. As mentioned above, I heard it on all but two, but no miss or Code.
Any and all thoughts would be appreciated.
Hard to say what it is. I'd try something inexpensive like seafoam first. It is a productfrom the 60's or sometime. Don't really know. All I can say is its good stuff. Put half of the can in your oil and the other half in your gas tank. Read the instructions. I can't remember if you need to change the oil shortly after or not. It has worked unsticking lifters for me before.
I don't know what it is, but I watched that video and I can tell you that is excessive chatter. I got a 2004 5.4 with 99,000 miles and it has the familiar tick, but that is all, no chatter like that. Mine does not not sound like the one in the video. So if yours sounds like that then yes it is excessively noisy.
^^^ I might just try that with mine (the guy with the videos in the other post). Problem is I just did an oil change last night..
edit:
now that I think about it maybe that isn't such a bad thing. Clean oil + engine flush (sea foam?) and new filter may be a good thing instead of waiting until the oil gets dirty
edit:
